What happened to Steve is terrible and I'm very sorry that happened. When I tested the frame I did many flights (but had no crashes) and to this date I had no issues with my PDB. If I would have known this could happen as it did to Steve, I would have done something about it. Adding nylon washers is a simple fix and I will include them for the next batch of frames about to go out.
I've also revised the PDB design which is currently manufactured as a prototype to confirm the new layout. The new design removes all copper from both layers from under the arms and bobbin connections. It also ads large 7mm diameter clearance around all the spacer screw holes.
The simple and low cost fix for everyone flying with the current frame and PDB is to:
A. add nylon washers for the screw heads sitting on the PDB surface (get M3 washers)
B. double check your motor mounting screws and make sure they are not driving into the motor windings, which can cause a short by itself and in combination with a scratched PDB
I don't think you need to wrap the arms as long as you have nylon washers. You just need to prevent the short on one side.
I am thinking about how to make the new PDB available to current customers that would like to update their PDB once it's available (it will be at least 3-4 weeks). It's probably a lot harder to de-solder the ESCs than it is to add nylon washers. Any suggestions on how to offer the updated PDB to current frame owners once it's available, please let me know.
Edited by timnilson, 25 July 2012 - 02:23 AM.
