Would this hexacopter frame work as a FPV quadcopter?
Posted 29 June 2012 - 03:47 AM
Posted 29 June 2012 - 04:02 AM
check it out here: http://www.multiroto...1132-XY-8-Build
Would be awesome to see something like this work with CopterControl/CC3D. I say try it out and see if you can make it work. I have a F550 as well that I was going to use for my TBS Discovery but would love to see what you come up with. Get after it.
Posted 29 June 2012 - 04:42 AM
QAV400 . QAV500 . Quadrixette 40 . TBS discovery . HT-FPV . HT-FPV prototype . VC-450 . UAP1 . youtube . juzfpv.com
Posted 29 June 2012 - 05:01 AM
25/2/2013
Quad - 01 Build Blog (Now Dead)
THE BEAST My RC Lawn Mower Blog
My Eurgle 2.4Ghz 9ch (Turnigy 9x clone)
HEX-01 - Build Log
FPVRaptor Composite 1600mm - Build Log
if i link to hobbyking i use Affiliate links that pay me a few cents each time you use them
Posted 29 June 2012 - 05:17 AM
EDIT: sorry steve.
Posted 29 June 2012 - 05:24 AM
25/2/2013
HEX-01 - Build Log
Posted 29 June 2012 - 08:13 PM
Why is this? Is it because of the asymmetrical layout or is there another reason?
No, hexas make poor quads
Does anyone know if the H550 hexacopter uses the same arms as the smaller Hobbyking Q450? I suspect the Q450 quadcopter frame has shorter arms but maybe it has the same arms and it's just the center plates on the H550 that are larger. I've already ordered the Q450 but I'll need to frabricate some landing gear if I want to mount my HD camera underneath so the props are out of view.
Edited by Steverino, 29 June 2012 - 08:14 PM.
Posted 29 June 2012 - 09:30 PM
no issue with what you want to do, been done before.
you will need to run a higher inner kp on the pitch axis, or increase the mix value on the pitch axis to compensate (as the motors are closer to the centre line in the pitch axis, they have less effect, so need either more gain or more "mix" to be as effective as the roll control) wont be much, maybe 20-30% more gain (i.e. if roll gain =0.001 then pitch will probably be 0.0013)
Posted 29 June 2012 - 10:57 PM
Posted 03 July 2012 - 11:49 AM
Y6 concept based on F550.jpg 48.31K
47 downloadsI'm planning on using a similar genuine DJI flamewheel F550 and turning it into a Y6 configuration.(This has been tried on RCgroups)I like the Y6 configuration over a quad. I read somewhere that they are more stable over a quad and have motor redundancy.
Here are some photos that I took from RCgroups.
Y6 concept based on F550 2.jpg 55.59K
82 downloads
Y6 concept based on F550 3.jpg 78.55K
80 downloads
Y6 concept based on F550 4.jpg 66.95K
63 downloadsStill waiting for all the motors and parts from Hobby king to try this Y6 configuration.
AeroR
Posted 10 August 2012 - 03:05 PM
Did you get them flying?
I ordered two of these just last night with the same thing in mind, then ran across your thread while searching google to see if someone else had tried it. I was thinking the exact same thing for the fpv quad and was thinking of trying to get a Y4 going too. Should be fun! I think it should work.
I ordered the $14 frames without the pcb.
Britt
Posted 11 August 2012 - 07:27 PM
Posted 11 August 2012 - 07:45 PM
Britt - you will be disapointed with a y4 - the yaw authority is piss weak, only suitable for flying indoors - not enough to overcome a breeze
Matt- Do you think Y6 could get more stable over quad?
Posted 11 August 2012 - 07:50 PM
I have the frames but I haven't had the time to build it yet. That Y-6 looks really interesting. Maybe I'll go that route instead. I like the motor redundancy. I accidentally ordered these 750 KV motors when I meant to order the 1250KV "Juz" motors. I'm wondering if the 750KV motors will have enough RPMs when running on my 3 cell battery packs.Steverino and AeroR ,
Posted 11 August 2012 - 09:32 PM
Rick
Posted 13 August 2012 - 06:40 AM
I can't remember- will CopterControl do Y6?
Rick
For sure !
http://wiki.openpilot.org/display/Doc/Multirotor+Mixer+Settings
QuadCopter (based on Talon frame)
Swift II
Hexa-copter personal frame (In progress...)
Posted 13 August 2012 - 07:20 AM
Also tagged with one or more of these keywords: H550, quadcopter
CopterControl Users →
CC/CC3D - MultiRotors →
quadcopter setup, please i need help!Started by barendbbs, 14 May 2013 |
Misc →
For Sale →
For Sale: Jago Heavy Lift Quadcopter - Bind and Fly!Started by YouMadeMeDoIt, 14 May 2013 |
Quadcopter - What is the advantage of larger or smaller frame?Started by suvro, 07 May 2013 |
OpenPilot General →
General Discussion →
Time to build a FPV (my first quadcopter)Started by SEJeff, 20 Apr 2013 |
OpenPilot General →
Human powered quadcopterStarted by Labcopilot, 16 Apr 2013 |
France
