3D print case for CC3D
262 replies to this topic
#1 jes1111
    Mechanical geek
  • 1451 posts
  • LocationWest Country
Posted 17 July 2012 - 02:39 PM
The new CC3D-only case is now detailed on the wiki and available at my Shapeways shop. B)
Jeremy
#2 D-OCHO
D-OCHO
  • 436 posts
  • LocationEurope
Posted 17 July 2012 - 02:43 PM
Can you say what is the difference with the CopterControl board case.
I have 2 of those but the cases from Frankenquad.
Wonder what I have to do to make them fit.
On the inside I mean.
Does the CC3D have the same dimensions??
Edited by D-OCHO, 17 July 2012 - 02:44 PM.
Open Pilot CC3D Quad (Dragon Link), Open Pilot CopterControl Minsoo Mini Quad (2,4 Ghz), Blade MCP X,Trex-250, KDS450S + Co-pilot II, Trex-600E + Flymentor, Spektrum DX7, Futaba T9CP Super, Phoenix RC Simulator, Traxxas 1/16 E-Revo VXL (TQ 2,4 Ghz).
#3 kevo
kevo
  • 358 posts
  • LocationSuffolk County NY USA
What exactly makes it only for the cc3d ??
    Banned
  • 5870 posts
Posted 17 July 2012 - 02:45 PM
I don't remember if this is all but there is a slight change in the USB connector position that made it not quite fit in the previous case :(
Testing crumple zones
#5 D-OCHO
D-OCHO
  • 436 posts
  • LocationEurope
Out of the Wiki
IMPORTANT NOTE: Due to some very slight dimensional differences, this case needs some minor modifications with a knife/file to fit the CC3D. A solution is being investigated but it is likely I'll produce a separate version for CC3D.
http://wiki.openpilo...terControl case
#6 Dream-fly
Dream-fly
  • 523 posts
  • Country: flag of India India
Posted 17 July 2012 - 02:49 PM
Wow! Jes How much does it weigh? 10gms?
#7 osnwt
osnwt
    Lemon's advocate
  • 2556 posts
  • LocationSevastopol
  • Country: flag of Ukraine Ukraine
Posted 17 July 2012 - 02:50 PM
USB connector and PWM outputs are a bit shifted.
#8 jes1111
    Mechanical geek
  • 1451 posts
Posted 17 July 2012 - 02:51 PM
Yep - the USB socket is set slightly further back (so the hole needed to be elongated) and the servo headers have moved slightly (about 0.85mm, but that makes a big difference!)
The new version also has the OP logo, an additional peep hole for the LEDs, an updated profile around the JST sockets (to prevent fouling with the connector 'wings') and the case screw holes are now big enough that a standard M3 hex head screw drops down out of sight.
Jeremy
#9 Gravity Thief
Gravity Thief
  • 1786 posts
Posted 17 July 2012 - 02:52 PM
As far as I no the output pins, and usb port are in slightly different places on the CC3D,
when compared to the CopterControl !
#10 skrider
skrider
    Too Much Work, Not Enough Play!
  • 170 posts
  • LocationApopka, Florida
Posted 17 July 2012 - 02:56 PM
So both the upper and lower portions of the case have changed? How far has the connector shifted? I asked this question to the devs/beta testers a few weeks back and was told that everything was the same.
That's a shame, I just recently purchased three CCv1 cases to eventually use with a CC3D (don't own a v1 either), so I guess they'll all need some trimming.
#11 jes1111
    Mechanical geek
  • 1451 posts
Posted 17 July 2012 - 02:57 PM
All three parts together weigh approximately 11g - plus your screws, of course.
Jeremy
#12 jes1111
    Mechanical geek
  • 1451 posts
Posted 17 July 2012 - 03:01 PM
Sorry about that - blame Dankers ;)
You could keep the lower case parts you have - you just need to shave about 1mm from the back of the aperture that fits around the USB socket. You could also hand-modify the top part to fit the new header position - again it's only about 1mm, but the Futaba tabs won't line up. If you order new "CC3D" top parts they will fit just fine with your "CopterControl" bottom parts. The clip is identical and works with both CopterControl and CC3D versions.
Jeremy
#13 jes1111
    Mechanical geek
  • 1451 posts
Posted 17 July 2012 - 03:57 PM
btw - reports elsewhere indicate that the CC3D fits okay in the Frankenquad case.
Jeremy
#14 skrider
skrider
  • 170 posts
Posted 17 July 2012 - 04:01 PM
Thanks for the info, good to know.
Nah, I won't blame Dankers, he's got a lot of blame free credit in the bank. I'm sure if they made such a change there was a good and necessary reason. :D
#15 Golden
Golden
    Official noob
  • 252 posts
  • LocationNYC
Posted 17 July 2012 - 06:23 PM
Jes, will the new stl files be available?
EDIT: nevermind, shoudla guessed that they are already up on the wiki. Looks awesome, love the new logo!
Edited by Golden, 17 July 2012 - 06:35 PM.
SQ-1 "Monitor" Foldable Quad Build Log: http://forums.openpi...-foldable-quad/
VC-450 "Yeti" Build Log: http://forums.openpi...s-vc-450-build/
Proud member of TGG
#16 ov3rmind
ov3rmind
  • 726 posts
  • LocationMillburn, NJ
Posted 17 July 2012 - 09:38 PM
Jes, fantastic stuff!! Quick question: would you be opposed if I used your source file to order a modified version of this case with a TGG logo added to it?
#17 jes1111
    Mechanical geek
  • 1451 posts
Posted 17 July 2012 - 09:51 PM
No problem! - do you have access to Solidworks or do you want to send me an EPS of the logo and I'll slap it on there?
Jeremy
#18 scphoto
scphoto
  • 399 posts
  • LocationNorthern NJ USA
Posted 17 July 2012 - 10:53 PM
I like the way you're thinking Mike!
#19 ov3rmind
ov3rmind
  • 726 posts
Posted 17 July 2012 - 11:12 PM
woohoo! thanks! If you could send the solidworks files, that would rock. I was going to use google sketchup pro, but seems it's not ideal :( Always wanted to putz around with shapeways. :)
#20 ov3rmind
ov3rmind
  • 726 posts
Posted 17 July 2012 - 11:16 PM
p.s. does dying from white to black give good results? I hear Rit dye can be obtained as easily as looking in the laundry aisles in walmart !
