Story: I originally mounted my camera with hot glue smothered ALL OVER! Yes, hot glue....FPV camera...What could go wrong! Well, i want to make things a bit better. I dont crash often, and reality is the part was only 12 bucks to print at shapeways as a test. This simply lays on top of the HT-FPV top-plate. 1mm thick mounting base, 4 points of screw-contact. Since flat is flat, 1MM is plenty. Shapeways strong/flexible plastic is durable, not brittle. In the event of a crash, i honestly dont see it breaking. on the edge of my CT lobes, its very thin. I can take my nail, and press into it, see a mark, that slowly springs back. Flexibility. Now the thicker 1mm stuff, tough to bend. So. I made 5mm diameter bars all around the camera, and back frame. This should be enough for a moderate crash, to 'bumper' the camera. Reality, the bars on the back are there to stop vibration. Hot glue did the job (no vibration) but only contact was the bottom. This, holds in the board at all sides.
Now with tolerances, what SHOULD happen is the board shouldn't glide in place. It should require a LITTLE bit of pressure, so its snug and happy.
As for the lens ring ... well, that can get cut off if its pointless. Thought why not experiment. It extends 2mm pass the lens. The goal of it (if its not in the video), was so in the event of a crash (or just getting your lens too close to the ground) something to take MOST the impact, before hitting the glass. Probably useless / stupid idea...but why not.
So. Wish me luck! Shapeways estimates ship by august 15 at the latest, plus i need to still send in my broken camera and get it replaced. The temp-replacement i got lacks the extended frame (vital for this jig to work). the 38mm, instead of the 32mm. that gives me 6mm of blank flat PCB with no components to run into. 5mm diameter pipes, 2.5mm of contact on PCB.
Your thoughts? The main point of the jig was to: Provide a camera holder which will securely mount the camera, keep vibrations down, and give SOME hope for protection if i ever crash.
Now that its 2:34 AM and i re-consider I work at 7AM and need to wake up at 6:30AM...Time for bed. Once I get started on an idea, I have a bad want to finish it. I already made the order after triple-checking dimensions
