Hello everyone i was wondering if I could get some help. I have some parts laying around and I would like to use them. Some of the I have not had luck with on other quads and since CopterControl Boards are so hard to come by I would like your input on either not it is compatible or can be made compatible.
Tiger Motor ESC 18a-
Tiger Motor ESC 40a-
Hyperion Atlas 25a-
3DR GPS uBlox LEA-6-
Thank You, any and all help is appreciated.
Note: The instructions for the CopterControl Board states: "In some rare cases or on high-end ESCs the ESC doesn't perform correctly without connecting the additional ground signal. In those cases it may be necessary to connect the ground wire to the ESC." Is thats the case for any of these?
