With all this in mind we needed a good alternative, while there are some other nice radio modules around, they are mainly too large, too heavy or far out of the price range of most people. So we did what all good engineering projects do, made our own; something perfect for UAV use, something with good range and a great balance of features Vs performance. Hence, the PipBee Pro was born.
The PipBee has a series of very exciting features, here are just some highlights:
- No breakout board needed, USB port and micro serial socket on board.
- Has the very powerful STM32 Microcontroller on board at 72Mhz.
- Open Source firmware licensed under the GPLv3.
- 250Kb/s data rate.
- API mode.
- AES encryption.
- Digital Spread Spectrum and Frequency hopping.
- Small, versatile footprint which is the same as OpenPilot AHRS & GPS, can be mounted in a stack on a Quad for example.
- Plug and play with the OP Cable set, OP will also power the board from this connector.
- Standard SMA antenna connector.
- When using with a PC, just a single USB cable is required, this will power the board as well as provide a USB to serial connection.
- Cross platform configuration tool - Mac, Linux & Windows.
- OpenPilot GCS support.
- Will utilise PiOS and other OpenPilot technologies.
- Fully certified radio and legal for license free operation in the global ISM bands.
434Mhz - Worldwide
868Mhz - Europe
915Mhz - USA, Australia & Israel
Power output is 100mw.
I'm extremely excited about these and it has been hard keeping quiet, there is still much testing left to do and code to write, more information to come as things progress.
Israel
