I attached 2 stack traces to point this out.
Config loaded twice
Started by Bani Greyling, Aug 14 2010 12:49 PM
2 replies to this topic
Posted 14 August 2010 - 12:49 PM
I see the configurations get loaded twice. It caused problems for me in that timer got set up twice. To work around this issue I added a flag to to prevent a second load. Not sure if other devs experienced the same.
What I cannot create, I do not understand - Richard Feynman
Posted 14 August 2010 - 01:18 PM
loadConfiguration() can be called several times, it is called every time a user chooses a different configuration in the dropdown list. If you need to do something only once, why not do it in the constructor? In general, the idea is that a gadget when loadConfiguration() is called 1. needs to unload the current configuration if necessary, and 2. load the new configuration. Most gadgets can just overwrite the old configuration variables and then 1. is pretty much nothing.
Posted 14 August 2010 - 08:01 PM
thanks Peter...
I'll make it work in that context then...
