ESC flashing with CRIUS USBasp v0.2
2 replies to this topic
#1 Dream-fly
Dream-fly
  • 541 posts
  • Country: flag of India India
Posted 01 January 2013 - 07:33 AM
Don't know if I got smart and ordered this
http://rctimer.com/i...26&productname=
from rctimer.  It's a CRIUS USBasp v0.2  for the KK board.  I really thought it was the same as the HK AVR programmer and since I was ordering a few more parts from rctimer, I thought I would include this as well.  Now I am stuck since all the documentation I have is around the HK AvR Programming card : http://www.hobbyking...idproduct=21321
and the pin-outs are not the same.
Has anyone used the CRIUS USBasp?  I would be humbled  :(
#2 charel
charel
  • 109 posts
Posted 01 January 2013 - 08:37 AM
It will work normally like with any other avr programmer.
You will have to figure out for yourself what pin on your programmer is which connection, but normally it should be an ISP. If so, the different connections are like in the following picture:
Now you have to google for the datasheet of your microcontroller (the biggest flat chip on one side of the ESC, should be something with atmega).
Now you have to find all the 6 pins like in the small diagram in the picture above. If you've found the pins that have those connections, use a multimeter/multitool to check for direct connections on your ESC layout where you can solder on to. Don't use small resistors, or you will destroy the ESC, look for soldering points of bigger parts, solder pads or places specially made for flashing (sometimes Mosi, Miso and SCK have special soldering points for easier flashing).
To be sure, check out this thread on RCG and look for your ESC and it's connection points:
http://www.rcgroups....d.php?t=1513678
Solder some cable to those points and connect them to the corresponding pin of the avr programmer.
It's better to understand a little than to misunderstand a lot.
#3 Dream-fly
Dream-fly
  • 541 posts
Posted 01 January 2013 - 01:26 PM
Thanks Charel.  and WoW!  Thought it was as simple as 123.  Any way  this is a good head start.
