First stabilized flight!
Posted 03 September 2010 - 12:41 AM
1) Overall, everything went as I anticipated. That means the bugs I expected to be a problem were, and plenty of things I didn't also were (the list goes on, transmitter battery failing, thinking I burned out the receiver when I reset some settings because switched from PPM transmission, etc. I did catch most of these the previous few days though).
2) Flying in the field near where my parents were camping while visiting was a mistake - not enough space and I was constantly tip stalling while trying to turn conservatively and avoid trailers)
3) Mounting my XBee on the front of the plane (getting it away from battery momentum in a crash) backfired when I broke the PCB in the first heavy landing (manual control) so there is no telemetry from this :-(
4) Absolutely need a bias correction for the attitude of AHRS. Because it's mounted on the top of the wing for me, there is 10-15 degree difference between the top and the bottom of the wing. The attitude for level flight is probably around 10 degrees. This error meant that whenever I switched to stabilized mode, it initially would dive to the ground. I hacked in an offset and that was too much, so afterwards it would jump up. Since I was trying to tell it straight-and-level I was jimmying the sticks to suggest the "correct" attitude I don't have a good feel for how well stabilization would work.
4a) I'm soliciting suggestions for a good way to learn this parameter. My current plan is to use the flight logging to grab a straight and level flight, then have a utility to post process, select a segment, and look at the average attitude during this. I thought at first putting it on a table would work but: 1) the table probably wasn't horizontal based on the influence of rotating the plane 2) the bottom horizontal != level flight. TL;DR: I tried this shit and it sucked.
5) Time for PID loop constants tuning. My ultimate goal, and a serious interest of mine, is wrapping some system identification into the flight hardware so it can automatically learn these (plus #4). As I said the area I was flying in was too small for me to feel that the stabilization was really rejecting perturbations from the wing and correcting. Also a delta wing with no yaw correction flying at 20 feet in a corridor of trailers is a terrible place to figure this out.
Also here is a second video showing a more successful flight with some telemetry (although it was dropping out - probably the modem damage)
Posted 03 September 2010 - 06:26 AM
Posted 03 September 2010 - 07:01 AM
Thought your a brave man to put so much trust into untested flight control software lol.
The videos would have been interesting to see how well (or not as the case maybe) OP works.
Posted 03 September 2010 - 09:34 AM
Posted 03 September 2010 - 12:07 PM
You're really brave man to fly without enough space to recover :-)
(I do this myself sometimes with my foam delta, but at least it was tested and proved to be controllable).
peabody124, on 03 September 2010 - 12:41 AM, said:
It is not very user-friendly, but I may only suggest to use separate Tx discrete channel to learn the system for level flight attitude. That is, you put model to straight and level flight, and then switch that channel to "save current attitude as default". I do not think that any other ways will work well enough (except if you manually choose correct segment what may be not so obvious and even less user-friendly).
Posted 03 September 2010 - 12:13 PM
I'll parse through the videos today and upload them. There's one that I think it worked quite well - but as I said it wasn't a long enough flight to really know what it was doing (and needs the cal/PID tuning).
That's a good idea and one of the things I was thinking. It could even be fairly user friendly - a GCS switch could say this time flipping into stabilize mode is a horizontal calibration mode too. I kinda like that plan because it doesn't require GCS (which I'm currently lacking in air).
Posted 03 September 2010 - 01:58 PM
peabody124, on 03 September 2010 - 12:13 PM, said:
It is pretty easy to switch the flight mode from the TX.
I was actually thinking of using some of the rotary controls on my TX to fine-tune the PID parameters. All in all I am still afraid this will require good coordination between laptop keyboard and TX handling at the same time, unless we use really high-end TX - or a custom firmware on the Turnigy 9X ;-)
How difficult would it be to add a calibration routine in the config gadget which says "Put your UAV horizontally and press the button", and detect the Pitch/roll bias - Yaw is not really an issue for basic stabilization, right ?
Posted 03 September 2010 - 02:01 PM
Posted 03 September 2010 - 03:11 PM
Edouard, on 03 September 2010 - 01:58 PM, said:
Posted 03 September 2010 - 03:21 PM
That was my first though, and I measured those values while it was horizontal and then hacked them into the code. Still not good enough (but swapped it from diving to ground to pulling up - much better). I think it needs to be in flight to know the attitude that keeps it flying straight & level. In the long run I'd love to do some system identification, just process a flight log - see from the AHRS when it was holding altitude and heading, and take the average of the attitude in all those segments.
For now I'm going with something similar Dschin suggested - use the rotary knobs to tune a bias term (I'll add a RPY). I like the idea of tuning the P term as well though. I'll maybe add a way that you can change what those knobs do if you want... I'll check this code in when written but wrapped if disabled #ifdef's.
Posted 03 September 2010 - 04:38 PM
peabody124, on 03 September 2010 - 03:21 PM, said:
I will be getting my Pandora within the next few weeks (www.openpandora.org) and I am definitely planning to use this as a small ground station. If it works as I hope it does, I will write a gadget with large buttons to access several functions such as "Set Level Flight" by just pressing the touchscreen - the goal being to avoid a crash while using the touchpad on a laptop in broad sunlight, something that is definitely bound to happen...
It is 1st of all a matter of defining new input channel types in the ManualControlCommand object, right? Then of course to have a module in the flight software which does something with those inputs...
Posted 03 September 2010 - 10:58 PM
Posted 04 September 2010 - 12:19 AM
Posted 04 September 2010 - 12:36 AM
Posted 04 September 2010 - 01:12 AM
Also good reflexes there
Posted 04 September 2010 - 07:09 AM
You can't beat a good piccy or video
Posted 04 September 2010 - 09:34 AM
Posted 05 September 2010 - 03:01 AM
Gary Mortimer, on 04 September 2010 - 09:34 AM, said:
Per your suggestions I dug out the old wing tips and it did help (as well as flying with some space so I could run it up). Good point about the throw too - I normally fly with exponential so don't use it all normally but it might make the plane too sensitive. I added a video above with another flight and some GCS video although the telemetry link wasn't very good (cracked modem)
Posted 07 September 2010 - 03:04 PM
Posted 08 September 2010 - 02:25 AM
I agree, for stabilized flight the bias is effectively controlled by the pilot, so if your pitch bias is -15 degrees your pitch command will need to be +15 degrees to keep the model flying level. So one could trim through the radio until the model is flying level, then when you land you check the AttitideDesired object and use those values for the bias (with the sign reversed).
France
Ukraine
