Someone has probably already figured this out, but I couldn't find it. You command line developers who have had a solution to this for some can stop laughing at us neophytes who depend on GUIs
The solution seems simple now but it was a pain in the butt to figure out. Eclipse (at least in windows) will not let you add command line arguments to arm-none-eabi-gdb. It chokes on them. I tried everything including writing a batch file with the arguments added and calling it rather than rather than arm-none-eabi-gdb directly. You also can't add the "define" command directly in the "Run commands" box because it chokes after the "define" where it sits and waits for you to input more rather than reading the next line. You can however add the line "source <filename>" in the "Run Commands" box and put the define commands in a file.
So here was my solution. See the attached screen capture. In the "Run Commands" box under the “Startup” tab of the debug configurations enter “source InterruptsInEclipse”, leaving the commands in the “Initiliaze Commands” box the same as the Eclipse project on the SVN. The file InterruptsInEclipse, which I am placing in the \flight\projets\gdb directory of the SVN should be copied to the \flight directory. If someone is clever enough to get it to find in the file \flight\projets\gdb directory, then even better.
The InterruptsInEclipse file is the following define commands.
define hook-step monitor cortex_m3 maskisr on end define hookpost-step monitor cortex_m3 maskisr off end define hook-stepi monitor cortex_m3 maskisr on end define hookpost-stepi monitor cortex_m3 maskisr off end define hook-next monitor cortex_m3 maskisr on end define hookpost-next monitor cortex_m3 maskisr off end define hook-finish monitor cortex_m3 maskisr on end define hookpost-finish monitor cortex_m3 maskisr off end
