So here is a little video on how to calibrate the INSGPS, and how to get it work for either indoor or outdoor use.
Note: currently selecting indoor mode where I did doesn't work. Use the UAVObject browser and change it under HomeLocation.Indoors.
INSGPS demo video
Started by peabody124, Sep 06 2010 09:50 PM
Posted 06 September 2010 - 09:50 PM
Posted 18 September 2010 - 09:19 AM
I've done the calibration, but does not see the model view tracking the AHRS as I expected. If I pitch nose up, it then banks instead.
Upon further investigation I saw that X and Y accelerometer data seem to get swapped around between raw data and and filtered data...not sure if this even relevant to what I see.
See attached screen dump of scope. The first rotation was around the Y-axis, and the second one was around the X-axis.
I was using the simple algorithm with the latest from the repository for pilot and ahrs boards.
Not sure where I've gone wrong...
I had the convention wrong, X is forward, and not Y...still looking into why my model view is not tracking my AHRS...
What I cannot create, I do not understand - Richard Feynman
Posted 18 September 2010 - 03:20 PM
Ok few thoughs:
1) plots look fine so accels not issue
2) are you in indoor mode?
3) have you got right gyro gain? -0.014,0.014,-0.014
4) does it move the wrong way then slowly correct?
5) check the values in attitudeActual. Raising arrow up should create positive pitch
Posted 18 September 2010 - 08:59 PM
By gyro gain, I take it you meen AHRSCalibration.gyro_scale: No, I had some weird values in there which caused by INSGPS algo to spin around, so I only tried SIMPLE algorithm. Set them to 0, and now it bank, pitch and roll better.
So at least now I have INSGPS sort of working. It does, however, not react as quick as yours...it takes about 12 seconds to settle if I for example bank.
Using insgps, I also get yaw to oscillate 25 deg every 12 sec if I pitch it 25 deg up, or bank 25 deg left.
Using simple, I get it to yaw 25 deg anti clockwise when I pitch it 25 deg up.
Using simple, I get it to yaw 25 deg clockwise when I bank it 25 deg left.
Posted 18 September 2010 - 09:42 PM
So if you have gyro gain 0 it will be slow because the gyros are saying it didn't rotate. In indoor mode I expect to see yaw rotation right now: no mag correction. In simple mode yaw and pitch/roll interact. I know why but that is just crude debugging.
