I did some Gyroscope temperature measurements. I got very weird results. Is this the right place to post it?
As you can see this is from a time compressed replay, the realtime replay would stretch over about half an hour ish or longer.
The jumps in accel raw come from shifting the frame to a new position. I had disconnected telemetry when moving the frame to the new spot to prevent peaks in the ahrs readings that would ruin the plots.
I get 50 degree with my frame's lid closed. Both GPS and OP get quite hot. I believe the AHRS has a lower temperature since it sits apart from the other components (especially the ESC/BEC which I believe to be the main heat source)
