Blackout's Mini H Quad
mini mini quad mini fpv mt1306 blackout mini h quad CC3D
7838 replies to this topic
#1 Blackout
Blackout
  • 1739 posts
Posted 21 June 2013 - 05:58 AM
http://www.minihquad.com/
Last Updated: 2013-09-17
The lastest specifications can always be found here: Blackout Mini H Quad Frame Kit
Original Post
Recently i designed & built my very own Mini H Quad frame.
The goal was to have a fast and durable mini FPV machine, basically a smaller version of the popular Flip FPV frame.
I wanted to use all high quality gear that i would normally use on a larger quad. This includes a nice CCD camera, a high power transmitter, antenna mount and a built in vibration dampening FPV camera mount.
Enough with the words, here is a photo of the completed project :)
Videos - Mobius Action Camera
Materials used are Carbon Fiber, 304 Stainless Steel and high quality Nylon 6/6.
The Arms and Legs are 2mm while the plates are 1mm thick.
MTM dimensions are 220mm diagonally x 175mm wide x 135mm long. Height is roughly 40mm (excluding legs)
The frame was designed in Solidworks to use the equipment listed below.
Motors: Tiger MT1306-10 3100kv - motor mounts accept 12-16mm M2 motor holes
Prop: 5x3 2 Blade GemFan
ESC: HK UBEC 6amp – SimonK
Battery: 2S 1500mah 35C/70C Nanotech
FC: FPVManuals CC3D
Receiver: FrSky D4R-II receiver – decased, 8 channel CPPM mode, tiny!
FPV Camera: SONY Super HAD CCD 600TVL D-WDR DNR Board Camera w/ 2.8mm lens (115 degree FOV) - built in camera mount accepts any 32mm x 32mm board camera
HD Camera: Mobius Action Camera
Video Transmitter: ImmersionRC 600mw Video Transmitter
Antenna: ImmersionRC SpiroNet
Voltage Regulator: Pololu 12V Step-Up Voltage Regulator U3V12F12 - for the 12v camera
1000mah 25/50C
AUW is 321 grams
AUW with 808 #16 Camera is 348 grams
AUW with Mobius Action Camera is 368 grams
1500mah 35/70C
AUW is 361 grams
AUW with 808 #16 Camera is 388 grams
AUW with Mobius Action Camera is 408 grams
Edited by Blackout, 17 September 2013 - 02:34 AM.
#2 Blackout
Blackout
  • 1739 posts
Posted 21 June 2013 - 05:59 AM
Build Log
These are some of the first screenshots of the first designs.
Then i made a paper version. Here it is next to my Samsung Galaxy S2.
Working with some forum members and CNC cuts, several changes were made to make it easier to cut and target some problems in advance.
Original leg design
These were revised to make them more flexible so the can be "snapped" onto the frame
Finally i got it cut and the wait started. Finally this Monday past a prototype appeared on my doorstep!
It might seem heavy, but strength is the goal here. Trust me, everything else is light :)
I stayed up real sanding down the Carbon Fiber edges and assembling. The next morning i got some nice photos.
Next was assembly. Some of you might has seen my Quadrixette Nano build, i used most of the gear of this.
CC3D test fit
I cut down the Board Camera as shown.
Then i dremeled the edges down
Camera mounting hardware includes 4x anti vibration mounts. I swapped the nuts out for Nylock as i dont want any nuts coming off in hard to reach places.
The Camera mount required a little filing of the edges to get it to fit perfect. I have adjusted my design to reflect this.
The antenna mount consists of a RG316 double shield 5cm right angle panel mount SMA connector. I used a heat gun several times to bend the tail into shape, this is part way through the process.
2x M5 316 stainless steel washers on either side to distribute force (the only M5 washers i had)
Antenna attached
Using Liquid Electrical tape i waterproofed my FPV camera, also it's black!
I put a bit too much on the back, but it will be fine :)
What it looks like when dry
Camera + Camera mount + anti vibration mounting = 17.1grams.... I'm happy with that :D
Battery beeper and voltage regulator
ImmersionRC 600mw 5.8ghz Video Transmitter
Battery mock
#3 Blackout
Blackout
  • 1739 posts
ESC & vTX mock
Motors attached
Receiver under CC3D
Propellers distances
Next flashing the UBEC 6amp ESCs. What a pain in the ass these little things were. Using the flash tool on 10amp or 12amps was much easier :P
I made a little flashing rig to touch the 4 programming pins using 4 long pin headers bent into shape and a little instamorph to hold it together. Jumper wires run back to the USBASP.
Stripping 3 of the ESCs positive and negative BEC wires
3.0g is light! but they end up lighter as seen below
I didnt like desoldering from the tiny FETs, so i trimmed the wires instead.
ESC mock
This is the painful part. I routed all of the wires down between the center plates and out the center hole. I made the center hole larger in the next version :)
Mocking battery connector wire routing
Creating the wiring for the video system. Helping hands defiantly help!
All cleaned up and looking pretty
Receiver position mocked again
Flip her over, time to start working on the power wiring.
Now i removed the bottom plate so i could access in between the plates.
How i solder each connection together. Keeping the soldering very small and flat to fit in the 2mm gap in between the plates.
I never soldered more than 3 wires together at a time, i just kept Y'ing them down til i got down to two wires. Very fiddly but it saves having big clumps of wires.
Tape it all up to hold the wiring in place.
Top side. In the center hole is the only place the wires cross over each other. The positive goes over while the negative goes under.
Bottom again. Getting closer.
Soldering in the camera system power harness.
I had to cut the inner side of the heat shrink to make the tight radius, a little liquid electrical tape makes sure there wont be any shorts.
Almost done! Final battery connector wires
I staggered the wire connections so there were no large clumps of heat shrink
Top Side
Bottom side
Put the bottom plate back on - nice and neat!
Top side again
After a little tidy up with most mocked up in their final positions
Time to attached the ESCs to motors. Dont forget the heatshrink!
Positioned for soldering
Escs done!
Rapstrap to hole them on
Battery connector added after mocking lengths
How it looks when complete
Finished! Time to break it!
Next to my Samsung Galaxy S2 for size comparison
AUW 321 grams
To get some HD footage for you guys, i added my 808 #16 v2 Lens D camera to the top, attached with rapstrap.
AUW with stock 808 #16 camera 348 grams
#4 eyesonsky
eyesonsky
    FPV addict
  • 1499 posts
  • LocationPreverenges
  • Country: flag of Switzerland Switzerland
Posted 21 June 2013 - 06:58 AM
Very nice build and great documentation.
Light and powerful, sure you will have fun with.
Joel
@youtube. . . . QuadH 470. . . . QuadH 310. . . . Team Red Kite
Discontinued : QuadX 1, QuadX 2, mini QuadH
#5 Terrier
Terrier
    Fly Me a River
  • 7580 posts
  • LocationNashville, Tennessee
Posted 21 June 2013 - 06:59 AM
Nice build log for a nice little copter.... Sweet! :)
#6 HelliYea
HelliYea
    Bang Ding Ow
  • Flight Test Team
  • 852 posts
  • LocationWarrandyte, Victoria
Posted 21 June 2013 - 07:38 AM
That is so great.  Really cool.  I think i need to build myself a mini quad.
1350 is the new 1200
3S is the new 2S
#7 dem0n1k
dem0n1k
    Major Malfunction
  • 665 posts
  • LocationBrisbane
Posted 21 June 2013 - 08:06 AM
Great design & execution Blackout.
Amazing attention to detail & excellent photography!
#8 jamesse007
jamesse007
  • 158 posts
  • LocationMalaga
  • Country: flag of Spain Spain
Posted 21 June 2013 - 08:23 AM
Amazing build man!! Real nice and clean!! Very impressed! Can't wait for some onboard footage!! ;)
QAV550
Quadrixette 40 mod to 48
Quadpod
V911
#9 neBstress
neBstress
    OP's resident monkey
  • 8197 posts
  • LocationSouth West
Posted 21 June 2013 - 08:36 AM
WOW, shes a beauty Blackout & great build log!
#10 Blackout
Blackout
  • 1739 posts
Posted 21 June 2013 - 08:39 AM
Thanks guys :D I try
Chances of flying tomorrow are looking good!
#11 Guest_salade_*
Guest_salade_*
  • Guests
Posted 21 June 2013 - 08:40 AM
When can I buy one? looks great.
#12 Petronio
Petronio
  • 1297 posts
Posted 21 June 2013 - 09:21 AM
Absolutely love this little fatty, looks really cool and the fpv cam sandwiched inbetween the plates protected in there is a great feature.
#13 Stisse
Stisse
    Too many multis
  • Flight Test Team
  • 125 posts
  • LocationHaparanda
Posted 21 June 2013 - 09:42 AM
Another amazing build Blackout, looks very very nice :)
My fleet:
Iconic-X FPV v2 (Revolution - TorxPower 2216 900kv - fpvmanuals 30A - 1,3MHz Rx 400mW Tx with Clovers - Sony 600 TVL CMQ1993X - GoPro 2)
Iconic-X FPV v2 (CC3D - Sunnysky 2212 980kv - F30A simonk - 1,3MHz Rx 400mW Tx with Clovers - Sony 600 CCD - GoPro 2)
Blackout Spider Hex (Revolution + GPS - Cobra 2204 2300kv - Afro 12a - Tx5200M 5,8GHz 200mW - Sony 600 CCD)
Mini 250 Clone (Naze32 - Dragonfly 2400kv - rcx10A - Tx5200M 5,8GHz 200mW - Sony 600 CCD)
Simple Tricopter 2.0 (KK2.0 - iPower 2212 1000kv - iFlight IQ22A)
RcExplorer Tricopter v3 (Revolution + GPS - Sunnysky 2212 980kv - Afro 30a - GoPro 2)
DYI.nu Hubben (KKmulticopter v5.5 fw QuadControl 4.7 - iPower 2212 1000kv - iPeaka 18A)
FY Y6 Scorpion (FY91Q + GPS - 950kv motors - ESC Hobbywing 20A)
Taranis with OPLinkMini for 433mhz
Spektrum Dx9 (Telemetry with GPS module, STI device)
FatShark Dom´s
My jutjub channel with not so good looking movies..
and
Homepage or Facebook
#14 tao
tao
  • 36 posts
  • LocationTampere
  • Country: flag of Finland Finland
Posted 21 June 2013 - 10:49 AM
Very nice! I like your build logs :)
http://pannuhuone.pro - Crashing things since 2012
#15 shama
shama
  • 254 posts
Posted 21 June 2013 - 01:52 PM
Superb !!! Excellent realization !
#16 Traveller
Traveller
  • 214 posts
  • LocationLeiden, Netherlands
Posted 21 June 2013 - 02:04 PM
Sweet looking mini quad Blackout!!!
"For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return." :D
#17 tech69x
tech69x
    Build Fly Crash Repeat
  • 249 posts
  • LocationSpring Texas
Posted 21 June 2013 - 04:41 PM
I've got to hand it to you Blackout you one hell of a designer and builder
#18 proudhon
proudhon
  • 14 posts
  • Country: flag of Belgium Belgium
Posted 21 June 2013 - 07:21 PM
Super impressive design and build log! Really looking forward to seeing some flight action! I hope the weather hold up for you.
#19 Blackout
Blackout
  • 1739 posts
Posted 21 June 2013 - 10:15 PM
Such great feedback :D
Weather looks great today! Maybe a little soggy, but meh!
Currently I'm working on the construction manual. I want it to be very clear and easy to follow with simple assembly drawings (what i would expect when i buy a frame)
I want to prototype another version of the frame, then i will do a production run for those that are interested.
If you have any questions, feel free to reply here or shoot me a PM.
#20 Petronio
Petronio
  • 1297 posts
Posted 21 June 2013 - 10:43 PM
Ouhh great! :)....doughh another frame to save money for, oh dear...
Also tagged with one or more of these keywords: mini, mini quad, mini fpv, mt1306, blackout, mini h quad, CC3D
