DUBwise for UAVTalk ( Android GCS )
Posted 09 April 2011 - 05:13 AM
here are some links to get started:
- https://market.andro...uavtalk.dubwise
- http://ligi-tec.blog...-over-time.html
- http://ligi-tec.blog...or-uavtalk.html
Posted 09 April 2011 - 03:32 PM
Frederic
Posted 09 April 2011 - 09:28 PM
Posted 10 April 2011 - 12:28 AM
Posted 10 April 2011 - 07:52 AM
Frederic
Posted 10 April 2011 - 08:01 AM
FredericG, on 10 April 2011 - 07:52 AM, said:
Frederic
Sorry if I am saying this wrong but there is a BT to Serial adapter on sparkfun that James is using with his Nook. That is then connected to an Xbee or PipXtreme.
Also, if you get an Androind with USB host support (Rooted Nexus 1 can do this and people are trying to get it going on the Nook), then a USB HID device like the PipXtreme should plug in also. Andrew also uses a Wifi to serial adapter as well, so again, WiFi -> Serial -> PipX.
Posted 10 April 2011 - 08:43 AM
I switched from zigbee to wi.232 because of fpv flying and from free2move to rayson btm since 2009 but the concept is the same and woks pretty well
Posted 02 May 2011 - 09:14 AM
Now one can search into uavobjects and general handling of them improved ( longclick brings description and metadata now )
Posted 02 May 2011 - 09:21 PM
Posted 02 May 2011 - 09:53 PM
Posted 02 May 2011 - 11:37 PM
Do you already know what Device you get? As i said earlier there are some Devices not working - some information about working/not working devices can be found here:
http://www.mikrokopt...seTestedDevices ( please ignore the J2ME ones there - DUBwise for UAVTalk is Android only at the moment )
But the list is way from complete. I am thinking about making an automated approach to make a way better one - DUBwise knows when it is connected and on which device it is running - just have to send that to ask the user if I can gather the Information and send it to a server backend.
Posted 17 September 2011 - 10:11 PM
I have wi32 wifi module instead of the Bluetooth one. Any chance to get dubwise working with wifi?
Thanks for your answer.
Posted 18 September 2011 - 10:42 AM
Posted 18 September 2011 - 02:08 PM
Posted 18 September 2011 - 02:16 PM
Please tell me what you see in the window called "Handshake status" which you get when you press the red or green square in the top
Posted 18 September 2011 - 02:25 PM
The connection is green (when I succesfully connects, I have several problems with the program forcing me to shut it down)
with rx packages coming in and no rx failures.
The PFD for example works great. But when I go to tuning I just get default values and not the values I know is omboard the quad.
Posted 18 September 2011 - 02:37 PM
Posted 18 September 2011 - 03:05 PM
ligi, on 18 September 2011 - 02:37 PM, said:
The font is unreadable BIG... (having the same problem on the alarms page):
SC20110918-165830.png 47.25K
17 downloadsI can see updates on some objects (like AttitudeActual), but not on the guidance ones.
I still think its a version mismatch on those objects. (You will not be able to ask for them since you got the wrong ID, so no "wrong" objects are sent back)
Posted 18 September 2011 - 04:35 PM
Posted 18 September 2011 - 08:53 PM
ligi, on 18 September 2011 - 04:35 PM, said:
(I updated to latest version with same result)
Please do something about the font. I get it all over the place. In the connection settings, in the alarms and on the UAVObject browser (However not when going in an looking at an object)
Belgium
