Mac Package: http://wiki.openpilo...14-2f7f920e.dmg
Windows Package: http://wiki.openpilo...20e-install.exe
PPM Only firmware: http://wiki.openpilo...7f920e-ppm.opfw do not use this for SBus, Spektrum or PWM inputs.
If you are upgrading from the June firmware this will erase all of your settings. Please use the export tool to save them before replacing GCS and then import the settings to the new program. Please remove all props while reconfiguring.. There is no guarantee this will work
The new firmware supports dynamic configuration of input type (except PPM see attachment) so one firmware will work for all input types. To see how to configure the input please see http://wiki.openpilo...rol HW Settings
This build also includes axis lock which I think was in the previous one and another mode called weak leveling. Weak leveling will slowly return the aircraft to level but otherwise behaves like rate mode. For notes on fine tuning these modes see the stabilization panel wiki page. This is documented on wiki but for Axis Lock you might want to change the maximum axis lock setting to 15.
Finally added optional flag for zeroing the integrals while low throttle. See notes in Stabilization Panel wiki.
Known problems:
1. To make this run on Lion and Snow Leopard I had to disable ModelView and the Notify plugins. Hopefully someone will fix these
We've been testing this firmware pretty heavily in the testing group so it should work but as always please watch out for any problems when using new firmware.
From HISTORY.txt:
2011-08-04 Fixed packaging aesthetic issues. Also avoid runtime issues on OSX Lion by disabling the ModelView and Notify plugins for now (sorry). 2011-07-29 Added support for PPM receivers from James W. Now all 4 interfaces (R/C standard PWM, combined PPM (MK), Spektrum satellite, Futaba S.Bus) are supported and configurable through the GCS hardware configuration tab. 2011-07-17 Updated module initialization from Mathieu which separates the initialization from the task startup. Also implements a method to reclaim unused ram from initialization and end of memory for the FreeRTOS heap. 2011-07-12 Improvements to the stabilization code. Included a LPF on the gyros to smooth out noise in high vibration environments. Also two new modes: axis-lock and weak leveling. Axis-lock will try and hold an axis at a fixed position and reject any disturbances. This is like heading-hold on a heli for the tail but can be useful for other axes. Weak leveling is rate mode with a weak correction to self level the craft - good for easier rate mode flying. 2011-07-07 Dynamic hardware configuration from Stac. The input type is now selected from ManualControlSettings.InputMode and the aircraft must be rebooted after changing this. Also for CopterControl the HwSettings object must indicate which modules are connected to which ports. PPM currently not working.
Update 2011-08-10: Updated with patch for integral windup for quads. If you downloaded 20110809-12ae607a when you update to this your StabilizationSettings will need to be reloaded.
Update 2011-08-11: Small update to 20110811-39fcc5bd for windows telemetry issue and graphical glitch in OSX
Update 2011-08-14: Update for NaN on a clean board and also the stack overflow when too many saves done
Netherlands
Ukraine
France
