With the OpenPilot board both bootloader-updater and firmware update seem to work right.
With the AHRS however this happens. The board gets detected, the uploader erases the flash rom, thenattempts uploading:
[16:08:13.644] [DEBUG] "DFUidle" qdebug
[16:08:13.650] [DEBUG] Starting Firmware Uploading... qdebug
[16:08:13.650] [DEBUG] Bytes Loaded= 10224 qdebug
[16:08:13.664] [DEBUG] NEW FIRMWARE CRC= 891687276 qdebug
[16:08:13.664] [DEBUG] Number of packets: 183 Size of last packet: 8 qdebug
[16:08:14.661] [DEBUG] 64 bytes sent qdebug
[16:08:14.661] [DEBUG] Erasing memory qdebug
[16:08:14.674] [DEBUG] StatusRequest: 64 bytes sent qdebug
[16:08:17.700] [DEBUG] StatusRequest: 64 bytes received qdebug
[16:08:17.704] [DEBUG] StatusRequest: 64 bytes sent qdebug
UPLOADING[> ] 0% [16:08:17.708] [DEBUG] StatusRequest: 64 bytes received qdebug
[16:08:17.708] [DEBUG] Erase returned: "" qdebug
[16:08:17.708] [DEBUG] Start Uploading: 183 4Bytes qdebug
UPLOADING[==> ] 4% [16:08:27.739] [DEBUG] StatusRequest: -110 bytes sent qdebug
[16:08:37.740] [DEBUG] StatusRequest: 0 bytes received qdebug
[16:08:37.741] [DEBUG] Upload failed (upload data) qdebug
[16:08:37.741] [DEBUG] UploadData returned: "abort" qdebug
and then gets this "abort" error.
Manually flashing the bootloader with make bl_ahrs_program works and the board gets detected again:
OpenPilot INS
Device ID: 201
HW Revision: 1
FGlash Access: RW
BL version: 0
Max code size: 122780
when I try to flash trhe firmware, again I get:
[16:17:06.090] [DEBUG] EnterDFU: 64 bytes sent qdebug
[16:17:06.094] [DEBUG] StatusRequest: 64 bytes sent qdebug
[16:17:07.138] [DEBUG] StatusRequest: 64 bytes received qdebug
[16:17:07.138] [DEBUG] "DFUidle" qdebug
[16:17:07.144] [DEBUG] Starting Firmware Uploading... qdebug
[16:17:07.144] [DEBUG] Bytes Loaded= 82000 qdebug
[16:17:07.158] [DEBUG] NEW FIRMWARE CRC= 1669951510 qdebug
[16:17:07.158] [DEBUG] Number of packets: 1465 Size of last packet: 4 qdebug
[16:17:08.154] [DEBUG] 64 bytes sent qdebug
[16:17:08.155] [DEBUG] Erasing memory qdebug
[16:17:08.166] [DEBUG] StatusRequest: 64 bytes sent qdebug
[16:17:11.193] [DEBUG] StatusRequest: 64 bytes received qdebug
[16:17:11.197] [DEBUG] StatusRequest: 64 bytes sent qdebug
UPLOADING[> ] 0% [16:17:11.202] [DEBUG] StatusRequest: 64 bytes received qdebug
[16:17:11.202] [DEBUG] Erase returned: "" qdebug
[16:17:11.202] [DEBUG] Start Uploading: 1465 4Bytes qdebug
[16:17:21.231] [DEBUG] StatusRequest: -110 bytes sent qdebug
[16:17:31.233] [DEBUG] StatusRequest: 0 bytes received qdebug
[16:17:31.233] [DEBUG] Upload failed (upload data) qdebug
[16:17:31.233] [DEBUG] UploadData returned: "abort" qdebug
It must be a bootloader issue. When I use bootloaders from the "master" trunk, there are no errors when uploading the AHRS firmware.
Edit: I suspect it to be a bl_openpilot issue. Switching the AHRS bootloader is not enough, I need to downgrade bl_openpilot to "master" in order to update the AHRS firmware.
