XXL-Wing, on 03 February 2012 - 07:05 AM, said:
for me it looks like this bug should be fixable with no big effort.. problem is that the GL subsystem tries to load the vertex buffer extension which is not present on some graphics cards or not exposed by some OSS drivers, so this is not a general issue but the crash will occur on chips or drivers without VBO. would be interesting if the guys that have the crash are using the closed source nvidia drivers or not and if not, if anything changes when they do. i'll have a look into that, if the framework is able to check for active extensions it should be easy to fix. btw: for a simple display like that, no VBO is needed anyway :-)
FWIW, I'm experiencing the segfault with the Intel drivers:
$ glxinfo
name of display: :0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
GLX_ARB_multisample, GLX_EXT_import_context, GLX_EXT_texture_from_pixmap,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_MESA_copy_sub_buffer,
GLX_OML_swap_method, GLX_SGI_make_current_read, GLX_SGI_swap_control,
GLX_SGIS_multisample, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGIX_visual_select_group, GLX_INTEL_swap_event
client glx vendor string: Mesa Project and SGI
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_import_context,
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_EXT_framebuffer_sRGB,
GLX_MESA_copy_sub_buffer, GLX_MESA_multithread_makecurrent,
GLX_MESA_swap_control, GLX_OML_swap_method, GLX_OML_sync_control,
GLX_SGI_make_current_read, GLX_SGI_swap_control, GLX_SGI_video_sync,
GLX_SGIX_visual_select_group, GLX_EXT_texture_from_pixmap,
GLX version: 1.4
GLX extensions:
GLX_MESA_multithread_makecurrent, GLX_MESA_swap_control,
GLX_OML_swap_method, GLX_OML_sync_control, GLX_SGI_make_current_read,
GLX_SGI_swap_control, GLX_SGI_video_sync, GLX_SGIS_multisample,
GLX_SGIX_fbconfig, GLX_SGIX_pbuffer, GLX_SGIX_visual_select_group,
GLX_EXT_texture_from_pixmap, GLX_INTEL_swap_event
OpenGL vendor string: Tungsten Graphics, Inc
OpenGL renderer string: Mesa DRI IntelĀ® Sandybridge Mobile
OpenGL version string: 2.1 Mesa 7.11
OpenGL shading language version string: 1.20
OpenGL extensions:
GL_ARB_multisample, GL_EXT_abgr, GL_EXT_bgra, GL_EXT_blend_color,
GL_EXT_blend_logic_op, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_copy_texture, GL_EXT_polygon_offset, GL_EXT_subtexture,
GL_EXT_texture_object, GL_EXT_vertex_array, GL_EXT_compiled_vertex_array,
GL_EXT_texture, GL_EXT_texture3D, GL_IBM_rasterpos_clip,
GL_ARB_point_parameters, GL_EXT_draw_range_elements, GL_EXT_packed_pixels,
GL_EXT_point_parameters, GL_EXT_rescale_normal,
GL_EXT_separate_specular_color, GL_EXT_texture_edge_clamp,
GL_SGIS_generate_mipmap, GL_SGIS_texture_border_clamp,
GL_SGIS_texture_edge_clamp, GL_SGIS_texture_lod, GL_ARB_framebuffer_sRGB,
GL_ARB_multitexture, GL_EXT_framebuffer_sRGB,
GL_IBM_multimode_draw_arrays, GL_IBM_texture_mirrored_repeat,
GL_3DFX_texture_compression_FXT1, GL_ARB_texture_cube_map,
GL_ARB_texture_env_add, GL_ARB_transpose_matrix,
GL_EXT_blend_func_separate, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_secondary_color, GL_EXT_texture_env_add,
GL_EXT_texture_filter_anisotropic, GL_EXT_texture_lod_bias,
GL_INGR_blend_func_separate, GL_NV_blend_square, GL_NV_light_max_exponent,
GL_NV_texgen_reflection, GL_NV_texture_env_combine4,
GL_SUN_multi_draw_arrays, GL_ARB_texture_border_clamp,
GL_ARB_texture_compression, GL_EXT_framebuffer_object,
GL_EXT_texture_env_dot3, GL_MESA_window_pos, GL_NV_packed_depth_stencil,
GL_NV_texture_rectangle, GL_NV_vertex_program, GL_ARB_depth_texture,
GL_ARB_occlusion_query, GL_ARB_shadow, GL_ARB_texture_env_combine,
GL_ARB_texture_env_crossbar, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_window_pos, GL_ATI_envmap_bumpmap,
GL_EXT_stencil_two_side, GL_EXT_texture_cube_map, GL_NV_depth_clamp,
GL_NV_vertex_program1_1, GL_APPLE_client_storage, GL_APPLE_packed_pixels,
GL_APPLE_vertex_array_object, GL_ARB_draw_buffers,
GL_ARB_fragment_program, GL_ARB_fragment_shader, GL_ARB_shader_objects,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ATI_draw_buffers,
GL_ATI_texture_env_combine3, GL_EXT_shadow_funcs, GL_EXT_stencil_wrap,
GL_MESA_pack_invert, GL_MESA_ycbcr_texture, GL_ARB_depth_clamp,
GL_ARB_fragment_program_shadow, GL_ARB_half_float_pixel,
GL_ARB_point_sprite, GL_ARB_shading_language_100, GL_ARB_sync,
GL_ARB_texture_non_power_of_two, GL_ARB_vertex_buffer_object,
GL_ATI_blend_equation_separate, GL_EXT_blend_equation_separate,
GL_OES_read_format, GL_ARB_color_buffer_float, GL_ARB_pixel_buffer_object,
GL_ARB_texture_compression_rgtc, GL_ARB_texture_rectangle,
GL_EXT_pixel_buffer_object, GL_EXT_texture_compression_rgtc,
GL_EXT_texture_rectangle, GL_EXT_texture_sRGB, GL_ARB_framebuffer_object,
GL_EXT_framebuffer_blit, GL_EXT_framebuffer_multisample,
GL_EXT_packed_depth_stencil, GL_APPLE_object_purgeable,
GL_ARB_vertex_array_object, GL_ATI_separate_stencil, GL_EXT_draw_buffers2,
GL_EXT_gpu_program_parameters, GL_EXT_texture_env_combine,
GL_EXT_texture_sRGB_decode, GL_EXT_timer_query, GL_OES_EGL_image,
GL_ARB_copy_buffer, GL_ARB_half_float_vertex, GL_ARB_map_buffer_range,
GL_ARB_texture_rg, GL_ARB_texture_swizzle, GL_ARB_vertex_array_bgra,
GL_EXT_separate_shader_objects, GL_EXT_texture_swizzle,
GL_EXT_vertex_array_bgra, GL_NV_conditional_render,
GL_ARB_ES2_compatibility, GL_ARB_draw_elements_base_vertex,
GL_ARB_explicit_attrib_location, GL_ARB_fragment_coord_conventions,
GL_ARB_provoking_vertex, GL_ARB_sampler_objects, GL_ARB_seamless_cube_map,
GL_ARB_shader_texture_lod, GL_EXT_provoking_vertex, GL_EXT_texture_snorm,
GL_MESA_texture_signed_rgba, GL_ARB_robustness
32 GLX Visuals
visual x bf lv rg d st colorbuffer sr ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a F gb bf th cl r g b a ns b eat
0x021 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x022 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0aa 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0ab 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0ac 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0ad 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0ae 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0af 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0b0 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0b1 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0b2 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0b3 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0b4 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0b5 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0b6 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0b7 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x0b8 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0b9 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0ba 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x0bb 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0bc 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0bd 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0be 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0bf 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0c0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0c1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0c2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0c3 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0c4 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0c5 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0c6 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x079 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
48 GLXFBConfigs:
0x07a 0 tc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x07b 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x07c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x07d 0 tc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x07e 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x07f 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x080 24 tc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x081 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x082 24 tc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x083 24 tc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x084 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x085 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x086 24 tc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x087 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x088 24 tc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x089 24 tc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08a 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08b 32 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x08c 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x08d 0 tc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x08e 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x08f 24 tc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x090 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x091 24 tc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
0x092 0 dc 0 16 0 r . . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x093 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x094 0 dc 0 16 0 r y . 5 6 5 0 . . 0 0 0 0 0 0 0 0 0 None
0x095 0 dc 0 16 0 r . . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x096 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x097 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x098 24 dc 0 24 0 r . . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x099 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x09a 24 dc 0 24 0 r y . 8 8 8 0 . . 0 0 0 0 0 0 0 0 0 None
0x09b 24 dc 0 24 0 r . . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x09c 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x09d 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x09e 24 dc 0 32 0 r . . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x09f 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0a0 24 dc 0 32 0 r y . 8 8 8 8 . . 0 0 0 0 0 0 0 0 0 None
0x0a1 24 dc 0 32 0 r . . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0a2 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0a3 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0a4 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 0 0 0 0 0 0 None
0x0a5 0 dc 0 16 0 r y . 5 6 5 0 . . 0 16 0 16 16 16 0 0 0 Slow
0x0a6 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 0 0 0 0 0 0 None
0x0a7 24 dc 0 24 0 r y . 8 8 8 0 . . 0 24 8 16 16 16 0 0 0 Slow
0x0a8 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 0 0 0 0 0 0 None
0x0a9 24 dc 0 32 0 r y . 8 8 8 8 . . 0 24 8 16 16 16 16 0 0 Slow
If you tell me what gdb commands to run after the segfault, I'd be happy to provide that information.
