I think that is fantastic! Cleaver use of the bridge board.
The next challenge is to write a CC firmware module that talks over the Flexi port to the D-OSD, it would basically read UAVOject values such as attitude and pass them along via I2C in the D-OSD protocol. I guess you know this, just a thought.
27 replies to this topic
#21
Posted 28 January 2012 - 03:24 AM
#22
Posted 28 January 2012 - 09:06 AM
LukeB, on 28 January 2012 - 02:27 AM, said:
Sure here's a link to the source code. https://bitbucket.or...b2208/osdbridge
It runs on an Arduino Pro Mini (3.3v ATMega 328). You'll need to connect the tx, rx, ground and power pins to the telemetry port on the CC. The Arduino is then connected to the dragon OSD i2c.
I checked it again this morning and it works with the code attached. I hope it's of some use to you, let me know if you have any questions.
Thanks for putting up your code, much appreciated!
I am only new to hardware programming - the pinnacle of my career so far is getting an Arduino Mega with LCD shield and GPS to show Lat and Long values. I would like to parse UAVObject information sent from CC via an Xbee and receive on my Mega via an Xbee then pull out GPS location and attitude for it. I was wondering if you could point me to the part of your code where you are only pulling out the information you want from UAVObjects?
I would also like to understand why you chose the 3.3 Arduino Pro Min instead of the 5v Arduino Pro Mini?
#23
Posted 29 January 2012 - 04:40 AM
The main reason for the 3.3v board was that I had one lying around already. Also I believe the DOSD uses 3.3v i2c but could be wrong. I remember seeing it somewhere but I just had a quick look and couldn't find the reference. It may still work with 5v but I'm not sure on this.
The sendAttitudeRequest function requested the attitude UAVObject from CC and the processMessage function parses the UAVObject response. I do recall seeing somewhere in the forum that someone has written an something a bit more complete for parsing UAVObjects for the Arduino. That's probably a better place to start than my code as I've just done it quick and dirty for this specific purpose. The other thing to note is that if the object id or structure of the attitude UAVObject change my code will break as I've hard coded these values.
#24
Posted 30 January 2012 - 06:02 AM
Thanks mate.
#25
Posted 31 January 2012 - 08:35 PM
It is 3.3V : Page 11
Very nice work, I might have to do ths as well!
#26
Posted 31 January 2012 - 08:39 PM
What Objects does it get? Will it also pass GPS through to the DOSD?
#27
Posted 01 February 2012 - 12:19 AM
Just the Attitude object.
No it doesn't pass through the GPS to the DOSD. It would be nice to but their firmware sources the barometer and imu data via i2c, and I assume their GPS data is via a serial protocol of some sort.
#28
Posted 24 February 2012 - 07:06 PM
Luke
Could you post pictures and parts you used also? A connectivity diagram would also be nice.
Also tagged with dosd, coptercontrol
OpenPilot International Forums →
Français →
Régler le biniouStarted by neobee, 11 May 2012 |
CopterControl Users →
MultiRotors →
CopterControl anti-vibration kit, need adviceStarted by bluesurviver, 02 May 2012 |
OpenPilot General →
General Discussion →
One CopterControl for sale on EBayStarted by bluesurviver, 23 Apr 2012 |
Helicopters →
OpenPilot CopterControl board availability?Started by joe_crash, 05 Apr 2012 |
MultiRotors →
FPV Wiring DiagramsStarted by kevinv033, 10 Mar 2012 |
Singapore
