I know that PA0 work because I've tried other configurations that worked on PA0. I have another 6 channel configuration where all channels on ADC1 work, but none on ADC2, which led me to believe that it was the ADC, but this configuration uses ACD2, and it works.
Any idea what I might be missing? I am re-sizing my queue buffer correct, so it's not that.
#define PIOS_ADC_USE_TEMP_SENSOR 1
#define PIOS_ADC_TEMP_SENSOR_ADC ADC1
#define PIOS_ADC_TEMP_SENSOR_ADC_CHANNEL 1
#define PIOS_ADC_PIN1_GPIO_PORT GPIOA // PA4 (Gyro X)
#define PIOS_ADC_PIN1_GPIO_PIN GPIO_Pin_4 // ADC12_IN4
#define PIOS_ADC_PIN1_GPIO_CHANNEL ADC_Channel_4
#define PIOS_ADC_PIN1_ADC ADC2
#define PIOS_ADC_PIN1_ADC_NUMBER 1
#define PIOS_ADC_PIN2_GPIO_PORT GPIOA // PA5 (Gyro Y)
#define PIOS_ADC_PIN2_GPIO_PIN GPIO_Pin_5 // ADC123_IN5
#define PIOS_ADC_PIN2_GPIO_CHANNEL ADC_Channel_5
#define PIOS_ADC_PIN2_ADC ADC1
#define PIOS_ADC_PIN2_ADC_NUMBER 2
#define PIOS_ADC_PIN3_GPIO_PORT GPIOA // PA3 (Gyro Z)
#define PIOS_ADC_PIN3_GPIO_PIN GPIO_Pin_3 // ADC12_IN3
#define PIOS_ADC_PIN3_GPIO_CHANNEL ADC_Channel_3
#define PIOS_ADC_PIN3_ADC ADC2
#define PIOS_ADC_PIN3_ADC_NUMBER 2
#ifdef ADD_ONE_ADC
#define PIOS_ADC_PIN4_GPIO_PORT GPIOA // PA0
#define PIOS_ADC_PIN4_GPIO_PIN GPIO_Pin_0 // ADC12_IN0
#define PIOS_ADC_PIN4_GPIO_CHANNEL ADC_Channel_0
#define PIOS_ADC_PIN4_ADC ADC1
#define PIOS_ADC_PIN4_ADC_NUMBER 3
#define PIOS_ADC_NUM_PINS 4
#define PIOS_ADC_PORTS { PIOS_ADC_PIN1_GPIO_PORT, PIOS_ADC_PIN2_GPIO_PORT, PIOS_ADC_PIN3_GPIO_PORT, PIOS_ADC_PIN4_GPIO_PORT }
#define PIOS_ADC_PINS { PIOS_ADC_PIN1_GPIO_PIN, PIOS_ADC_PIN2_GPIO_PIN, PIOS_ADC_PIN3_GPIO_PIN, PIOS_ADC_PIN4_GPIO_PIN }
#define PIOS_ADC_CHANNELS { PIOS_ADC_PIN1_GPIO_CHANNEL, PIOS_ADC_PIN2_GPIO_CHANNEL, PIOS_ADC_PIN3_GPIO_CHANNEL, PIOS_ADC_PIN4_GPIO_CHANNEL }
#define PIOS_ADC_MAPPING { PIOS_ADC_PIN1_ADC, PIOS_ADC_PIN2_ADC, PIOS_ADC_PIN3_ADC, PIOS_ADC_PIN4_ADC }
#define PIOS_ADC_CHANNEL_MAPPING { PIOS_ADC_PIN1_ADC_NUMBER, PIOS_ADC_PIN2_ADC_NUMBER, PIOS_ADC_PIN3_ADC_NUMBER, PIOS_ADC_PIN4_ADC_NUMBER }
#else
#define PIOS_ADC_NUM_PINS 3
#define PIOS_ADC_PORTS { PIOS_ADC_PIN1_GPIO_PORT, PIOS_ADC_PIN2_GPIO_PORT, PIOS_ADC_PIN3_GPIO_PORT }
#define PIOS_ADC_PINS { PIOS_ADC_PIN1_GPIO_PIN, PIOS_ADC_PIN2_GPIO_PIN, PIOS_ADC_PIN3_GPIO_PIN }
#define PIOS_ADC_CHANNELS { PIOS_ADC_PIN1_GPIO_CHANNEL, PIOS_ADC_PIN2_GPIO_CHANNEL, PIOS_ADC_PIN3_GPIO_CHANNEL }
#define PIOS_ADC_MAPPING { PIOS_ADC_PIN1_ADC, PIOS_ADC_PIN2_ADC, PIOS_ADC_PIN3_ADC }
#define PIOS_ADC_CHANNEL_MAPPING { PIOS_ADC_PIN1_ADC_NUMBER, PIOS_ADC_PIN2_ADC_NUMBER, PIOS_ADC_PIN3_ADC_NUMBER }
#endif
#define PIOS_ADC_NUM_CHANNELS (PIOS_ADC_NUM_PINS + PIOS_ADC_USE_TEMP_SENSOR)
#define PIOS_ADC_NUM_ADC_CHANNELS 2
#define PIOS_ADC_USE_ADC2 1
#define PIOS_ADC_CLOCK_FUNCTION RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_ADC2, ENABLE)
#define PIOS_ADC_ADCCLK RCC_PCLK2_Div8
/* RCC_PCLK2_Div2: ADC clock = PCLK2/2 */
/* RCC_PCLK2_Div4: ADC clock = PCLK2/4 */
/* RCC_PCLK2_Div6: ADC clock = PCLK2/6 */
/* RCC_PCLK2_Div8: ADC clock = PCLK2/8 */
#define PIOS_ADC_SAMPLE_TIME ADC_SampleTime_239Cycles5
/* Sample time: */
/* With an ADCCLK = 14 MHz and a sampling time of 239.5 cycles: */
/* Tconv = 239.5 + 12.5 = 252 cycles = 18�s */
/* (1 / (ADCCLK / CYCLES)) = Sample Time (�S) */
#define PIOS_ADC_IRQ_PRIO PIOS_IRQ_PRIO_LOW
// Currently analog acquistion hard coded at 480 Hz
// PCKL2 = HCLK / 16
// ADCCLK = PCLK2 / 2
#define PIOS_ADC_RATE (72.0e6 / 1.0 / 8.0 / 252.0 / (PIOS_ADC_NUM_CHANNELS >> PIOS_ADC_USE_ADC2))
#define PIOS_ADC_MAX_OVERSAMPLING 36
