Flights with CC on Heli videos, first take off, some flips and 3D
Posted 05 November 2011 - 04:24 PM
this is some of the videos i made yet.
This is my first flight, all settings default.
This is my first flips.
Posted 05 November 2011 - 05:23 PM
Can you please share your settings exported to a file? It would be interesting to compare, I still cannot tune mine at least to a point at where you at... mine is a bit sluggish and not very stable in rate hover.
Posted 05 November 2011 - 05:27 PM
Posted 05 November 2011 - 05:35 PM
Very nice!
Sure, i will keep posting my settings here.
http://zulu.globalar...pilot/settings/
BTW: tail is reversed.
Posted 05 November 2011 - 07:41 PM
Posted 05 November 2011 - 10:30 PM
Posted 06 November 2011 - 12:45 AM
Great work Dezent!
Thank you
*looking into settings* Thanks Dezent, quite interesting!
I will post better settings tomorrow, i have just started to configure my heli
and it is starting to be able to some serious flying.
have a look tomorrow and you will see some improvements
and remember that my tail is reversed if you are going to try my settings.
Posted 06 November 2011 - 03:13 AM
OK, thanks, I'm mostly just comparing the rates and mixer numbers, I see yours are much higher.have a look tomorrow and you will see some improvements
I guess I was too cautious, maybe that's the reason mine was not very stable/controllable.
Posted 06 November 2011 - 08:21 AM
Having it way too low can be worse than slightly too high. Try it on a quad to see what I mean (safer to try on a quad lol).
Posted 06 November 2011 - 05:59 PM
Very nice!
I have the same issue with heli not being very stable in hover, trying to figure it out.
Will post settings
Posted 06 November 2011 - 08:28 PM
I have tried with my 500 and not yet found a sweet spot.
I will take a look at your settings and try these out.
Which servos are you using?
Posted 07 November 2011 - 10:58 AM
Great- Thanks for sharing.
My setup is.
Align Trex 500
Swash: 3x Align DS510, 1520us neutral, 333hz
Tail: MKS DS8910, 760us neutral, 560hz
Motor: Align 500L
ESC: Hobbywing 100A
Blades: Align 425 Carbon fibre FBL
Tail: Align Carbon Fibre
FBL Head: RJX
FBL Controller: CopterControl
Battery: 6s 3000mah 35c
Throttle curve is 100 100 100 100 100
Posted 12 November 2011 - 06:42 PM
*** Warning ***
tail is reversed, servo update speed is 400hz on tail
and 333hz on swash.
Change this before connecting servos if your machine can't do that.
Always armed is enabled, configure throttle hold and remove blades.
Posted 14 November 2011 - 02:55 PM
now gains are a little bit higher and Gyro Tao is raised a little bit.
http://zulu.globalar...-2011-11-14.uav
CC behaves much better now but still have some trouble holding an axis
given to it.
Posted 21 November 2011 - 07:23 AM
I'm 3d heli pilot and all i can say if i would use flybarless system i wouldn't settle for less than microbeast controller, idealy v bar to be on safe side. Flybarless is very demanding stuff, it's not like if you louse 1 servo in flight with flybar, if flybarless controler goes crazy, DAMN, RUN! hehe
btw awesome work there, it's unbelivable that OP cc board can do what you guyz achived, amazing =)
Posted 23 November 2011 - 12:57 AM
This trex had beastx before i upgraded to CC
Did not dare to use the X5 for testing CC, i think it would be plain stupid to try something like that..
I am trying to keep the heli far away, hovering close is ok but inverted hover i try to keep it at least 20 meters away,
one thing i found out is that CC is very calm, it is not doing any twitches, if it shakes from to much gain.. well it shakes but there
is no problem taking it back for landing. Its more like a flybar heli with a non level swash plate.
I have one problem that i need to figure out, but i don't think its cc related is that unlike other systems that keep an angle if you release
the sticks my trex just fall down from that angle like its balancing on a big ball. Like i said, I'm not even sure if this is CC or vibrations yet.
Posted 04 January 2012 - 04:03 AM
Posted 10 January 2012 - 11:27 AM
dezent: Just FYI, I added some of your most recent .uav file settings to "Successful Helicopter Stabilization Settings" at http://wiki.openpilo...ning+Helicopter
Very good idea to have that list!
I hope i can provide even better values soon, we have winter in Sweden now
with mostly storm and rain/snow, when it gets a little bit colder i can start doing
some more testing
I will also do some testing with vibration dampening and also try a CC case i got from JoeCNC
to bring more mass to the CC.
Posted 10 January 2012 - 03:19 PM
some more testing
Is that case something that is for sale? If so, do you have a URL?
Good luck with your winter test flights.
Posted 06 February 2012 - 09:55 PM
after extensive flight testing with two different cc boards, i could not get my Trex 500 to keep axis after letting go
of the sticks so it just drifted and almost fell over if i was not correcting all the time.
Then i noticed...
To prevent oscillations at this level Gyro Tau has been raised to .04 from .005 default.
i had been thinking this was a typing error before since my Gyro Tau has been around 0.005
but no, i found that he actually was using 0.04 and i went outside and tried this.
With freezing fingers ( -6c) and almost no light on the parking lot outside
i had a great little hover with my Trex 500
and i could let go of the sticks and heli kept attitude without a problem in both axis lock and rate
Now its time to start tuning for real.
This config looks flies OK, cc is sitting on left side of heli, do not load if you have analog servos.
http://zulu.globalar...ed-Gyro-Tau.uav
Italy
