Mounting APC props on dt750 motors question
11 replies to this topic
#1 bestever
bestever
  • 71 posts
  • Country: flag of Greece Greece
Posted 07 November 2011 - 05:54 PM
Dt750 motor's shaft is a 4mm screw.
APC's closest ring supplied ring is 5mm diameter.
my solution to this,  is using fuel silicon tube as a sleeve around the shaft to achieve a snag fit. But I dont know if this a proper way to avoid vibrations.
any ideas - recommendations?
#2 Aerhead
Aerhead
  • 222 posts
Posted 07 November 2011 - 06:13 PM
I don't know about vibrations but I use tubing with out problems but I'm not doing AP.
Edited by Aerhead, 08 November 2011 - 05:13 AM.
#3 noxus
noxus
  • 194 posts
  • Country: flag of Belgium Belgium
Posted 07 November 2011 - 08:22 PM
Just did a quick google search. How about this prop adapter.
http://www.headsuprc...-for-4mm/Detail
#4 ANV
ANV
  • 256 posts
Posted 07 November 2011 - 08:55 PM
I know some guys using heat shrink tube with no issues.
#5 bestever
bestever
  • 71 posts
Posted 07 November 2011 - 11:00 PM
Thank you for your input.
I don't know if I can use this adapter with the screw type shaft of Dt750 motors.
that sounds interesting, I'll give it a try!
#6 Efliernz (Pete)
Efliernz (Pete)
  • 21 posts
  • LocationHamilton,
Posted 08 November 2011 - 07:04 PM
#2 vote for heatshrink.  Just be sure to heat it evenly so it shrinks evenly...
Pete
#7 the_0ne
the_0ne
  • 28 posts
  • LocationEkaterinburg
Posted 09 November 2011 - 02:05 PM
I use this solution:
Small piece of  aluminum tube with outer diameter - 5mm.
It works very nice)
#8 bestever
bestever
  • 71 posts
Posted 09 November 2011 - 02:31 PM
Now , that's nice, great idea!
I hope I'll find a tube with 4mm inner diameter and 5mm outside diameter though....
#9 bobrcnut
bobrcnut
  • 17 posts
Posted 01 February 2012 - 01:57 AM
Try these...   http://www.allerc.co...pcs-p-1570.html
#10 bestever
bestever
  • 71 posts
Posted 01 February 2012 - 04:14 AM
Great stuff!!
Ordered 20pieces :D
#11 John888
John888
    Learning by doing :-)
  • 172 posts
  • LocationBalmain
Posted 01 February 2012 - 02:08 PM
Kalimera bestever,
I just use cable (zip) ties. 2 x 2.5mm per prop, attaching to the bell.
Can pretty much use any prop that way.
Have done about 10 flights like this so far without a prob.
Below is a video from a keychain cam. Quality isn't great, but enough to see.
Homebuilt Y6 Hexacopter (750kv motors, 11" and 12" props) - lifting a DLSR
Homebuilt FPV Quadcopter (1200 kv motors, 9" props) - lifting 1-2 GoPros
Homebuilt Tricopter (750kv motors, 11" props) - lifting 1-2 GoPros
Hombuilt Endurance Tricopter - 40+ min hover time (360kv motors, 15" props)
Bixler Plane (FPV enabled)
1900mm Skywalker Plane (on its way - to be FPV enabled)
Experimenting with ER9x, FrySky & a 1 watt booster
Experimenting with DIY 5.8ghz Cloverleaf, Skew Planar Wheel & Helicals
#12 bestever
bestever
  • 71 posts
Posted 02 February 2012 - 05:12 PM
zip ties was my "invention" when I builded my first tricopter and the only part missing was prop adaters. I didn't even know there was such a part.....
My experince with zit ties though wasn't that good, cause the generated vibrations I couldn't get rid off.
How they're doing in your application in terms of vibration?
