http://www.ic-board....-MX353-OEM.html
Its a system on a chip 532 MHz AMR11 with 256MB DDR2 RAM - running linux - the board is roghly the same size as CC and weights only 7 gram. Perfect any powerful on-board number high level computation tasks. (It could run the GCS if it wanted)
It interfaces with 4 50-pin Hirose connectors which unfortunately do not interface with anything we have directly, so it needs a breakout board, IC-board offers a variety of dev-boards which are nice for development, but too big and way too heavy for anything airborn. Also needs power supply and stuff in a way compatible with OP/CC
So I designed and built my own - interfaces with CC/OP-PRO via USB. (The mx353 has an inbuilt host controller) and also features some serial uart's for its own IO, and an on-board micro-SD card for mass storage:
Schematics: http://cybertrench.c...b/mainboard.sch
I used as little SMD components as possible. The big through-components have the advantage of spanning significant board area which helps routing more on the front layer:
http://cybertrench.c...b/mainboard.brd
The guys at http://www.shackspace.de (a hacker space in Stuttgart) have an ink-jet printer capable of printing acid resistant ink directly on copper. I used that to print and edge this little baby
Soldering those 200 tiny pins was a PITA:
But it was worth it:
Since I had almost no things on the back, I skipped the back layer and used bridges/wires instead
And it works!!!!
Flemish Belgium
Switzerland
