Antenna diversity
pipx pipxtreme rf diversity
13 replies to this topic
#1 LeeS
LeeS
  • 336 posts
  • LocationLake City, Florida
Posted 14 November 2011 - 03:13 AM
Since the RFM22B module supports antenna diversity, is there any chance we can get dual antenna support on the PipX?
It would require very little in the way of additional circuitry (from what I read in the datasheet)
#2 dankers
  • 5124 posts
Posted 14 November 2011 - 08:47 AM
The question is what antenna connection style to use that will both fit on the board as well as be robust. Currently we use SMA, which I really don't like much as they are heavy and a crash would likely result in the damage to the board.
Open to antenna style suggestions
#3 K Wells
  • 2228 posts
Posted 14 November 2011 - 11:23 AM
How about u.FL  This type is very common on many internal laptop wifi boards. it does not take up much real estate and would have high survival rate.
IPX is another brand name
#4 DrewF
DrewF
  • 162 posts
  • LocationChicago, IL
Posted 14 November 2011 - 11:33 PM
I like it, but since it's a compression fit I would be concerned with vibrations knocking it off.  Maybe I'm way off though since I know it's common in laptops and the idea is that it's light enough it shouldn't matter.
Guess worst case is a dab of hot glue to make it solid? :)
#5 peabody124
Posted 15 November 2011 - 12:11 AM
There are U.FL. connectors on the Gumstix and they feel damn tight.  Their downside is the female end (antenna) isn't good for many reconnects but I don't think that's a big problem myself.
#6 peabody124
Posted 15 November 2011 - 12:18 AM
The problem with antenna diversity is it does start adding components to the existing design - I'd rather keep it simple and elegant.
#7 mnuapel
mnuapel
  • 64 posts
  • Country: flag of Czech Republic Czech Republic
Posted 15 November 2011 - 12:40 AM
SMPM connectors could be perfect, we use them. They are much smaller than SMA, yet big enough to be robust, and mating force is high enough not to worry about vibrations. But I am not sure about price, i am afraid they are too expensive.
http://www.jst-mfg.c...talog_SMPMe.pdf
http://www.te.com/ca...69&U=&BML=&LG=1
Probably nothing can beat SMA, once price comes into consideration
#8 peabody124
Posted 15 November 2011 - 01:13 AM
Man in low quantities SMA through holes are still like 6$!
#9 naiiawah
naiiawah
  • 309 posts
  • LocationNorthwest USA
Posted 15 November 2011 - 02:26 AM
Very common connector in WiFi gear as well.  On one WiFi eval demo board kit I've seen, they put a pair of 3mm holes on either side of the connector.  Goint through the holes, they had a small zip tie around the board and connector via the holes with a couple of millimeter square piece of dense foam on top of the connector and under the zip.  No way that thing was coming loose on their demo!
#10 dankers
  • 5124 posts
Posted 15 November 2011 - 02:01 PM
We did exactly the same thing on an earlier GPS board that uses an external antenna with U.FL. Works great.
#11 Brian
Posted 15 November 2011 - 03:05 PM
Would it be hard to add a wire antenna option?  It would be nice for smaller "indoor" craft that don't need the range to have an option of a smaller/lighter antenna.
#12 Les Newell
Les Newell
  • 178 posts
Posted 15 November 2011 - 03:17 PM
Most FrSky receivers use U.FL connectors and I've never had one come off, even in severe crashes. You could also then use FrSky replacement antennas instead of having them made up.
#13 naiiawah
naiiawah
  • 309 posts
Posted 15 November 2011 - 07:01 PM
If the frequencies are a match for the antenna, than this alone would make it worth using that connector!
#14 naiiawah
naiiawah
  • 309 posts
Posted 15 November 2011 - 07:03 PM
+1
WiFi modules commonly do this.  PCB trace "Wire" antenna by default with the U.FL connector for an off board antenna.
