Quadrixette 30 frame for Open Pilot Copter Control
#41
Posted 16 December 2011 - 08:06 PM
how about these motors. http://www.hobbyking.com/hobbyking/store/__4699__hacker_Style_Brushless_Outrunner_20_50S.html
Is the KV too low you think?
Or how about these? http://www.hobbyking.com/hobbyking/store/__2049__hacker_Style_Brushless_Outrunner_20_34S.html
KV too high on these?
I have used the 2022Ls from the same brand on my larger quads with great results. they are a bit pricey but I know they are quality.
I may try to make a stabilized mount for my gopro so maybe I should error on the side of being overpowered rather than underpowered.
Or maybe even these perhaps. http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=5684
I really have no idea how to pick out motors. I alway go with a reccomendation. So I really do appreciate your help.
#43
Posted 16 December 2011 - 09:20 PM
I order the same combo motor/ESC 15-18A and 2 over 5 esc fried on the bench without even applying throttle input.... I think you will be better with some turnigy plush 18A...
ThanksURNIGY Plush 1
importon, on 16 December 2011 - 05:59 PM, said:
I'd like to try and get everything I can from hobbyking to save $$$
Also what size (mAh and ?C) lipo are you running with a gopro mounted?
how about escs? these ? http://www.hobbyking...15_18A_ESC.html
or these? http://www.hobbyking..._8_10A_ESC.html
#44
Posted 17 December 2011 - 10:24 AM
As with the nano arms, they are cut in length, but not drilled. This can be done extremely easy with the provided drilling template.
Picture will follow later today.
#45
Posted 17 December 2011 - 05:56 PM
#46
Posted 17 December 2011 - 06:51 PM
#47
Posted 20 December 2011 - 05:14 PM
#48
Posted 20 December 2011 - 05:20 PM
#49
Posted 20 December 2011 - 05:25 PM
Fredator, on 20 December 2011 - 05:14 PM, said:
Nice Work....Fred, could you post a component list as a guide to this build?
#50
Posted 20 December 2011 - 06:17 PM
Uploading short video now, coming up in a bit.
K Wells: sure thing, Just ordered the Quadrixette 30 frame, GoPro Cam Mount and a Mounting Plate for the CC FC at Elias' shop. I am using a T-Rex 500 LG which fits perfectly (will require you to enlarge the holes slightly).
Other than that:
- 4x A2208/17 outrunners
- 4x 12A Turnigy ESCs
- 8x4.5 props
- using two 3S 1000mAh Turnigy lipos
Edited by Fredator, 20 December 2011 - 06:22 PM.
#51
Posted 20 December 2011 - 06:54 PM
Oh, and just in case you might be afraid to crash the frame: The most "fragile" part of the setup is the connection of the GoPro-housing with the frame. Thats where the polyamid-screws come into play: In case of a crash, they will just "snip off". In 9 of 10 crash tests i've done they didn't even break and could just be screws in afterward. The housing itself also is very crash-resistant. I even did stand on the housing to test it, and it carried my 75kg very well :-)
Looking forward to the video!
btw: it's Felias! ;-)
Edited by Felias, 20 December 2011 - 06:54 PM.
#52
Posted 20 December 2011 - 09:01 PM
Here is the short video:
Didn't even mess with the board settings yet... me in love! Great job on the frame :-) As soon as I find some time off, I will shoot and post a couple of outdoor vids.
Edited by Fredator, 20 December 2011 - 09:36 PM.
#53
Posted 20 December 2011 - 09:46 PM
#54
Posted 20 December 2011 - 10:21 PM
#55
Posted 22 December 2011 - 02:06 AM
#56
Posted 22 December 2011 - 07:22 AM
Thanks! I've ordered the motors here: http://www.giantcod....r-p-405609.html
I am using 12A Turnigy ESCs, although 10A should be just fine if you happen to have some of those.
Best,
Fred
#57
Posted 22 December 2011 - 05:55 PM
Best,
Fred
#58
Posted 22 December 2011 - 06:20 PM
#59
Posted 28 December 2011 - 04:20 PM
for those of you who have their bird in the air already: Could you please post your settings (+used motors)? I think this would greatly help others.
Thanks,
Nic
#60
Posted 28 December 2011 - 08:25 PM
I like! It flew better than I expected for a first flight.
The electronics were transfered straight from my CrashCopter frame without modifications or re-tuning and it flew instantly.
Controller : OpenPilot CopterControl
Frame : Quadrixette 30
Motors : Gaui 330X-S Scorpion 1050kv
EScs : Gaui 330X-S 10A
Props : Gaui 8"
LiPo : Zippy 3S 2100 35C
Landing gear: home made
Weight incl. GoPro and LiPo: 818 gram
Weight without GoPro and LiPo: 515 gram
The frame went together very easy. Everything was a perfect fit.
The only minor surprise was that the battery plate didn't fit the holes in the arm.
(I drilled exactly with the template, but the slightest deviation from the center of the arm-to-mainplate holes will be exaggerated at the point of the battery plate)
I had to redrill slightly closer to the quad center.
You might want the fit the arms first and then determine the position of the battery plate holes.
I replaced the wing nuts by plastic stand-offs. (a few grams lighter)
Not finished yet, need to get rid of the Nichiban and Scotch tape, tidy up the wires and balance the props.
The video tx will be on the top plate, the velcro is already there. Still need to make a video cable.
The straws at the back are to keep the antennas in place.
Edited by Mark II, 29 December 2011 - 07:05 AM.
Netherlands
Belgium
