Mini Quad Funsize
#41
Posted 28 November 2011 - 04:42 PM
http://www.blueskyrc...&products_id=30
I will be using 2-3 cell lipos and small fpv camera from hobby king.
#42
Posted 28 November 2011 - 05:04 PM
http://www.hobbyking...?idproduct=5358
here is the Turnigy version and they are in stock
http://www.hobbyking...tor_2000kv.html
the Plush 6A is out of stock
http://www.hobbyking...Controller.html
I used the Exceed Proton 6A
http://www.hobbypartz.com/proton.html
#43
Posted 28 November 2011 - 05:38 PM
Im thinking of using 4-5" propellers with this micro frame, do you think If I use 2cell lipo (2200mah) it will be to heavy if I will use this Turnigy 1811 Brushless Motor 2000kv?
#44
Posted 28 November 2011 - 05:46 PM
Mark Langille
http://www.flitelab.com
#45
Posted 28 November 2011 - 05:50 PM
#46
Posted 28 November 2011 - 05:58 PM
The difference in weight is only 6 grams. The HK 18-11 are problematic where the motor mounts could easily come loose and the hex keys could eventually strip after a crash or adjustments.
The other picture is my home made frame, 180g total weight. I have crashed a few times and broken several props.
Just need to make several more tuning adjustments, but it fly.
#47
Posted 28 November 2011 - 06:01 PM
#48
Posted 28 November 2011 - 06:08 PM
I'm waiting for my A1510s, I was curious how much they actually weigh. 6g more isn't too bad for a more substantial motor. The sales stuff said 26g but I figured that was probably for shipping calculations. Maybe I'll remove the RX case and pins like c2Po did.
#49
Posted 28 November 2011 - 06:27 PM
http://ardrone.parro...t.aspx?i=221867
Franco
"Don't gain the world and lose your soul, wisdom is better than silver or gold." - Bob Marley
see my fleet in my Mad Scientists Lab at The Lab
#50
Posted 28 November 2011 - 06:28 PM
kelvinator, on 28 November 2011 - 04:32 PM, said:
The biggest issue has been the motors not all of the motors produce equal power. I have ordered in 4 more motors and am going to try them.
Yeah, those motors are not the of best quality for sure...
#51
Posted 28 November 2011 - 06:30 PM
F
#52
Posted 28 November 2011 - 06:31 PM
Kamikazepilot, on 28 November 2011 - 05:38 PM, said:
I'm using 2200mAh on a Gaui 330X and still think it's heavy for it, but on a mini quad... the whole quad weighs less than this battery.
#53
Posted 28 November 2011 - 06:36 PM
Spydmobile, on 28 November 2011 - 06:30 PM, said:
With those that most people use the rpm will be too high and you would need much smaller props, I guess maybe something like 4 x 2.5 or even less.
Don't know if that would make sense, 2S seems to be a perfect fit so far.
#54
Posted 28 November 2011 - 06:39 PM
AlPackin, on 28 November 2011 - 06:08 PM, said:
Yes, that 26g listed on the site looks suspicious for such a small motor.
#55
Posted 28 November 2011 - 06:40 PM
So it looks like they are around 16g? Not bad, thanks.
#56
Posted 28 November 2011 - 06:48 PM
F
#57
Posted 28 November 2011 - 06:49 PM
Well, it seems overkill for a mini. Im thinking to use my old 2S lipo thats why
#58
Posted 28 November 2011 - 06:51 PM
Mark Langille
#59
Posted 28 November 2011 - 06:56 PM
Kamikazepilot, on 28 November 2011 - 06:49 PM, said:
#60
Posted 28 November 2011 - 07:01 PM
C2PO,
The (A1510 -KV2200) I received have the correct prop mounts for the GWS 3x5 props. No need to drill the props holes to 4mm.
This was stated in a different thread.
