Radio Communication Module
I also posted this under the Hardware Development part of the forum so it would be in a place where people could find it. This is a mix of links that I have found for both video on RF radio for telemetry. I hope it helps if you are searching for long range use. The prices range from under $15.00US to $500.00 US or more depending on what you are trying to do.
www.4netonlin.com
2.4 GHz-Outdoor Bi-directional 250mw to 5 watt amps.
http://www.4netonlin...&category_id=92
5.8 GHz-Outdoor Bi-directional 250mw to 5 watt amps
http://www.4netonlin...&category_id=95
Wireless AP/Bridge 900 MHz to 5.8 GHz
http://www.4netonlin...&product_id=831
Embedded Radios / Spectrum Analyzer, 2.4 GHz & 900 MHz
http://www.4netonlin...&product_id=626
_________________________________________________________________
Radio Chips Transceiver & more.
www.abccom-tech.com
Multi-Channel RS-232 RF Transceiver: RF-232
http://www.abacom-te...232-P93373.aspx
900 MHz Spread Spectrum Radio Data Transceiver: SSRT-09-RS232
http://www.abacom-te...232-P93405.aspx
2.4GHz Spread Spectrum Radio Data Transceiver: SSRT-24-RS232
http://www.abacom-te...232-P93471.aspx
433MHz & 900 MHZ Multi-Channel USB RF Transceiver: RF-USB.
http://www.abacom-te...USB-P93372.aspx
DFROBOT
APC220 & APC 802 Radio Communication Module
APC220 Radio Communication Module
http://www.dfrobot.c...1&product_id=57
APC802 Radio Communication Module (2800 meters)
http://www.dfrobot.c...&product_id=375
________________________________________________________________________
www.elechouse.com
http://www.elechouse...products_id=316
NRF24L01 + PA wireless module (PTR6000A) 400 m
http://www.elechouse...products_id=605
NRF24L01+ PA and LAN Wireless Module •Transmission distance(Open area): 520m (2Mbps)/750m(1Mbps)/1000m (250Kbps)
http://www.elechouse...roducts_id=2139
Multichannel 1200m Wireless TTL Serial Module + Antenna
http://www.elechouse...products_id=323
NRF2401A Wireless Data Transmission Module
http://www.elechouse...roducts_id=2150
915MHz CC1101 Wireless Module
http://www.elechouse...roducts_id=2148
CC1101 Wireless Data Transmittion Module V2
http://www.elechouse...products_id=802
www.bevrc.com
BEV-FY-602 data radio, 433 MHz; ISM band, transmission distance of up to 10000m(500WM)
http://www.bevrc.com...adio-p-221.html
BEV-FY-605 data radio, 433 MHz; ISM band, transmission distance of up to 10000m- 2000m (2 Watt)
http://www.bevrc.com...adio-p-220.html
L-Com antennas and everything else.
http://www.l-com.com/home.aspx
www.digi.com
XBee
http://www.digi.com/...oint-rfmodules/
Wireless Range Extenders and Peripherals
http://www.digi.com/...rs-peripherals/
Wireless Modems and Peripherals
http://www.digi.com/...ms-peripherals/
FLYTRON
OpenLRS Receiver v2
http://www.flytron.c...eceiver-v2.html
7W booster for 433Mhz
http://www.flytron.c...er-for-uhf.html
Freewave
LRS455 435-470 Licensed Radios
http://www.freewave.com/HOME.aspx
MIcroBee
Radio Modem
http://www.microbee-...com/product.php
X-Lin
900 MHz to 5 GHz, 100 Mw to 5 Watt Long Range wireless Lan’s
http://www.hotware.c...products_01.htm
Larid Technologies LLC
900 MHz FHSS technology, 5mw to 1000mw, API commands to control packet routing, Laird Technologies' "masterless" protocol, allowing each transceiver to communicate with any other in-range transceiver for true peer-to-peer operation.
http://lairdtech.sta...ers/ac4790-1000?
910MHz Modules
http://lairdtech.sta.../910mhz-modules
915 MHz Wireless Module
http://lairdtech.sta...3001696|3001845
868MHz Modules
http://lairdtech.sta.../868mhz-modules
2.4 GHz Modules
http://lairdtech.sta...2-4-ghz-modules
Proprietary Radio Modules
http://lairdtech.tho...ules?&plpver=10
Bluetooth Radio Modules
Microhard Systems Inc
900 MHz Spread Spectrum Wireless Modem
http://www.microhard...Spectra920A.php
2.4GHz Industrial Wireless Modem
http://www.microhard...Spectra2420.php
3.4GHz OEM S-Band Frequency Hopping Wireless Modem
http://www.microhard...Spectra3420.php
OEM 900 MHz Spread Spectrum Wireless Modem, Nano Series
http://www.microhardcorp.com/n920.php
Miniature 2.4 GHz Spread Spectrum Wireless Modem
http://www.microhardcorp.com/n2420.php
Miniature 3.4 GHz Spread Spectrum Wireless Modem
http://www.microhardcorp.com/n3420.php
Mini Kits
http://www.minikits.com.au/index.html
LINEAR AMPLIFIER KITS
http://www.minikits.com.au/kits7.html
WENSHING Electronics Co.,Ltd
Hi Power Radio Modem 434MHz / 925MHz
http://www.rf.net.tw...em/Radio_Modem/
Sequoia Website
M868-TinyPro 868 MHz radio modem 500mW 4Km
Http://www.sequoia.co.uk/components/product.php?d=3&c=38&f=4&p=962&fmt=grid
OpenLRS
http://code.google.com/p/openlrs/
Scherrer LRS Long Range ( direct)
http://www.webx.dk/r...3/uhf-link3.htm
Scherrer LRS Long Range (Via ReadyMade)
http://www.readymade...e=index&cPath=8
Seed Open Hardware Fab.
Home Page
http://www.seeedstudio.com/depot/
Wireless
http://www.seeedstud...-c-139_140.html
www.streakwave.com
Ubiquiti Networks,
http://www.streakwav...ct-ubiquiti.asp
Ubiquiti XtremeRange 9, 900MHz (XR9) - US Version
http://www.doublerad...&category=38564
APPCON Technologies
APC -200, 230, 240, 801, 802, and 960
http://www.appcon.co...nxilie_cls.html
Sparkfun
XTend 900 1W RPSMA - 40 Mile Range
http://www.sparkfun.com/products/9411
No replies to this topic
