Sambas, on 18 June 2010 - 02:31 PM, said:
Can you record i2c trafic?
Yes, I have a logic analyser and a I2C -> usb device I sometimes borrow from work.
Can you record few config-blobs? Like reset defaults, enable osd, different videoformat, and maybe enable one datablock and move it around the screenslots, just change one setting each time.
Yes, this is the procedure I have in mind, it just takes time. This is why I proposed to compose a few config-blocks that could could fit most peoples needs.
I should get my osd next week and I'd like to start play with it.
Do you mean, using it or help develop?
Without eLogger I currenlty see two issues:
- Without configuration(-blob) with OSD will not display anything.
- I currently work with version 1.15 of the OSD firmware, yours might come with a slightly older FW, might works well, but not sure
Both issues could, in theory, be solved by having a mechanism of storing the FW and config on the SD card and that the driver could send that to OSD at startup, but this is too much work for this weekend.
Perhaps there is somebody who could lend you an eLogger.
Frederic
