Qt 4.8 released
Posted 15 December 2011 - 02:49 PM
http://labs.qt.nokia...4-8-0-released/
Don't forget to get Qt Library instead of Qt SDK for getting qmake and all the necessary stuff for compiling.
Posted 17 December 2011 - 09:27 AM
d:/OP/opgit/os_gcs/ground/openpilotgcs/src/libs/glc_lib/viewport/glc_camera.cpp: 441: error: 'gluLookAt' was not declared in this scope mingw32-make[7]: *** [release/glc_camera.o] Error 1 d:/OP/opgit/os_gcs/ground/openpilotgcs/src/libs/glc_lib/viewport/glc_viewport.cp p: In member function 'void GLC_Viewport::updateProjectionMat()': d:/OP/opgit/os_gcs/ground/openpilotgcs/src/libs/glc_lib/viewport/glc_viewport.cp p:155: error: 'gluPerspective' was not declared in this scope d:/OP/opgit/os_gcs/ground/openpilotgcs/src/libs/glc_lib/viewport/glc_viewport.cp p: In member function 'GLC_Point3d GLC_Viewport::unProject(int, int) const': d:/OP/opgit/os_gcs/ground/openpilotgcs/src/libs/glc_lib/viewport/glc_viewport.cp p:227: error: 'gluUnProject' was not declared in this scope d:/OP/opgit/os_gcs/ground/openpilotgcs/src/libs/glc_lib/viewport/glc_viewport.cp p: In member function 'QList<GLC_Vector3d> GLC_Viewport::unproject(const QList<i nt>&) const': d:/OP/opgit/os_gcs/ground/openpilotgcs/src/libs/glc_lib/viewport/glc_viewport.cp p:254: error: 'gluUnProject' was not declared in this scope
Posted 17 December 2011 - 01:07 PM
Sambas, on 17 December 2011 - 09:27 AM, said:
http://forums.openpi...l-oss-with-480/
Posted 17 December 2011 - 02:28 PM
Posted 17 December 2011 - 10:03 PM
Posted 18 December 2011 - 09:52 AM
How good is Quick3D? Is it a full replacement?
Posted 19 December 2011 - 04:28 PM
Posted 06 January 2012 - 08:19 AM
Posted 06 January 2012 - 05:11 PM
Posted 06 January 2012 - 05:52 PM
Posted 08 January 2012 - 10:26 AM
Posted 08 January 2012 - 11:51 AM
Posted 09 January 2012 - 03:04 AM
PT_Dreamer, on 08 January 2012 - 11:51 AM, said:
Posted 27 February 2012 - 11:43 AM
Posted 27 February 2012 - 07:20 PM
Posted 27 February 2012 - 08:21 PM
Posted 28 February 2012 - 03:44 AM
Posted 26 March 2012 - 08:40 PM
Since starting new topics might not be taken kindly I took the effort to find this thread...
Context of this post to me anyhow is that I want to build on windows (windows xp 32bit) clean windows install, and given the instructions, I set upon installing the next phase, after
-Git
-CodeSourcery
-Python2.7
- and the QT ...
Since the indications in the wiki indicate that I will probably be better of installing QT4.8, I am trying to do just that.
However when at 59% progression into the installation, "Installing component USB Network Driver"
an "Installation Error" occurs :
"Error during installation process (com.nokia.ndk.tools.madde.usbdriver):
Execution failed(Unexpected exit code:-2147418112):"C:
\QtSDK\Madde\usbdriver\DPInst.exe /SE /SA /SW" "
... this happened with the online and the offline links in the wiki being :
http://wiki.openpilo...ding on Windows
--> http://qt.nokia.com/...sdk-windows-cpp
--> http://qt.nokia.com/...ows-cpp-offline
With the offline install link I attempted to pick the 4.7 version, but with same error for usb.
Also given that not everybody has unlimited bandwidth available at home I thought I would mention this.
At this point I am in panick mode because I am not sure wheter this would play nice with GCS and the HID type of device the coptercontrol module enumerates to.
This may as well have something to do with nokia doing some extreme alpha releasing ( did not dig into this use case )
Thanks for any pointers and hope to contribute when possible.
Finland
Ukraine
Belgium
