voltage issues causing firmware corruption?
corrupt firmware voltage trou
6 replies to this topic
#1 dowlinger
dowlinger
  • 25 posts
Posted 07 January 2012 - 07:17 PM
I am guessing this is voltage related, as I try to tune the CC I find this issue coming up consistantly.
It seems whenever I have a " small accident ( Fall over/flip) I need to relaod the firmware and redo the settings to get it back into the air.
I also happens when
I get a low battery condition ( I am running 2s )
Even unplugging amd replugging in the battery.
Last night I left the craft working fairly well when I went to bed.
This morning I plugged it in and It was irratic/unflyable
Here are the symptoms.
Z axis on the compass is spinning fairly quickly and dos not stop.
Yaw meter on the CGS moves back and forth full scale and does not stop ( I unplug the receiver to see if this is an issue but nothing changes.)
throttle becomes very touchy and gose from idle to full throttle in a very qiickly ( 2 clicks of trim )
This along with a couple other "issues"
It never seems to happen in flight, but if I have to replace a battery, I can be sure that I will be redoing all of the settings as well.
I relaod the firmware, and it seems I also need to redo all of the settings, and it is fine until the next time.
I am lucky to get a full battery through before I have to do the same thing again.
I spend 75% of my time reloading firmware and redoing settings and 25% in flight setup, have yet to get more than 3 feet off of the ground.
Hope this is information that helps
Paul
Edited by dowlinger, 07 January 2012 - 07:19 PM.
#2 David J
David J
  • 746 posts
  • LocationBentley, Suffolk
Posted 07 January 2012 - 07:35 PM
I think you'll find that the next release of software (GCS & firmware) will address this problem (hopefully).
This is in an advanced state of testing, to be released as soon as it is judged to be ready.
This page intentionally left justified...
#3 dowlinger
dowlinger
  • 25 posts
Posted 07 January 2012 - 07:50 PM
Hey, thanks for the reply,
So this is a known issue?
Is there a workaround in the meantime.
I can not even use the board, and I am sure not everyone is having this issue, or it would never have been released..
paul
#4 David J
David J
  • 746 posts
Posted 07 January 2012 - 08:43 PM
dankers mentioned an interim release in another thread - hopefully he can comment...
#5 dowlinger
dowlinger
  • 25 posts
Posted 07 January 2012 - 09:00 PM
thanks to the IRC
I have identifies my issues, yes issues, i believe 2 of them.
1: I understand there is an issue regarding the gyros going crazy if the power is quickly switched on and off. I think it was referred to as the 30 second rule.
2: Since I am using 2s, my little flips land on the props stalling the motors causing the esc's to draw enough power to pull my vcc down to brownout, which as I also understand id another issue with the flash memory on the chip.
So between the two issues, I was having all types of issues, but atleast now i know why, and hopefully this will help spome others as well
hopefully a fix will be along shortly
Cheers
Paul
Edited by dowlinger, 07 January 2012 - 09:01 PM.
#6 c2po
c2po
  • 796 posts
  • LocationAtlanta, GA
Posted 07 January 2012 - 10:37 PM
http://wiki.openpilo...ttings-fix.opfw
Download and flash this firmware, it has that problem fixed.
#7 dowlinger
dowlinger
  • 25 posts
Posted 08 January 2012 - 12:56 AM
Perfect thanks
Just flew more in the last few minutes than I have since I got it.
This is what I expected, and love it.
Here is pa pic of my micro quad
Stable as a rock, and i haven't really tuned anything too much yet
inner P=1.7 I=1.7 thats it
thanks all
Paul
Edited by dowlinger, 08 January 2012 - 01:19 AM.
