Error while building on Windows
11 replies to this topic
#1 Berkely
Berkely
  • 615 posts
  • Country: flag of Flemish Belgium Flemish Belgium
Posted 10 January 2012 - 10:59 AM
I've been building the Windows package for a few months without issues. But now it seems there are some errors:
$ make package
CC		 flight/PiOS/STM32F10x/Libraries/STM32_USB-FS-Device_Driver/src/usb_mem.c
CC		 flight/PiOS/STM32F10x/Libraries/STM32_USB-FS-Device_Driver/src/usb_regs.c
CC		 flight/PiOS/STM32F10x/Libraries/STM32_USB-FS-Device_Driver/src/usb_sil.c
LD		 build/bl_coptercontrol/bl_coptercontrol.elf
c:/progra~2/codeso~1/source~1/bin/../lib/gcc/arm-none-eabi/4.5.1/../../../../arm
-none-eabi/bin/ld.exe: section .boardinfo loaded at [08002f80,08002f9f] overlaps
section .data loaded at [08002ee0,08002fd3]
collect2: ld returned 1 exit status
mingw32-make[3]: *** [c:/Users/sysadmin/OpenPilot/build/bl_coptercontrol/bl_copt
ercontrol.elf] Error 1
mingw32-make[2]: *** [bl_coptercontrol_install] Error 2
mingw32-make[1]: *** [all_bl] Error 2
mingw32-make: *** [package] Error 2
I cannot recall myself changing anything what would be the cause. Is there anything changed or does this error seems familiar to anyone? I have to admit I didn't dive into it yet.
#2 PT_Dreamer
  • 1211 posts
Posted 10 January 2012 - 02:07 PM
Make sure you are using the latest arm toolchain.
#3 Berkely
Berkely
  • 615 posts
Posted 27 January 2012 - 10:29 PM
I have to come back on this, I installed a SSD (huge difference), installed all programs needed & described in the wiki & the readme. But I run into exact the same problem. Upgraded to the latest Sourcery CodeBench Lite & to QT1.1.4 but that's the same.
I must be missing something ( & I think the wiki also).
#4 PT_Dreamer
  • 1211 posts
Posted 27 January 2012 - 11:01 PM
Can you post a screen shot of the same command with the upgraded system
#5 Berkely
Berkely
  • 615 posts
Posted 29 January 2012 - 08:15 AM
It looks mainly the same:
Building with the following command looks like this:
$ make package 2>&1 | tee make_log.txt
Spoiler
Building with make CLEAN_BUILD=NO package 2>&1 | tee make_clean.txt
results in:
Spoiler
I tried onlt the GCS via the batch file from the wiki which resulted in the following error.
Spoiler
I hope this makes sense.
#6 Sambas
Sambas
  • 244 posts
  • Country: flag of Finland Finland
Posted 29 January 2012 - 08:49 AM
First two "error: variable 'dummy'" comes from latest codesourcery, You can go around it by removing -Werror flag from CC makefile.
#7 robert b
robert b
  • 100 posts
  • Locationschneisingen
  • Country: flag of Switzerland Switzerland
Posted 29 January 2012 - 09:11 AM
hi,
what means latest?
there a different sources when building arm eabi toolchains.
#8 PT_Dreamer
  • 1211 posts
Posted 29 January 2012 - 02:36 PM
By latest I mean the latest installer package available from codesourcery's webpage as pointed in the wiki. You should note this thread tittle.
@Berkely - please try the switch Sambas referred or delete the unused var.
#9 Berkely
Berkely
  • 615 posts
Posted 30 January 2012 - 09:27 AM
I tried switching between to the previous codesourcery but the error was the same.
So I've commented the _Werror flag which seems to work till the next error.
A make package results in:
../PiOS/STM32F10x/pios_spi.c: In function 'PIOS_SPI_TransferByte':
../PiOS/STM32F10x/pios_spi.c:294:10: warning: variable 'dummy' set but not used [-Wunused-but-set-variable]
CC		 flight/PiOS/STM32F10x/pios_ppm.c
CC		 flight/PiOS/STM32F10x/pios_pwm.c
CC		 flight/Libraries/fifo_buffer.c
CC		 flight/Libraries/CoordinateConversions.c
CC		 flight/PiOS/STM32F10x/Libraries/CMSIS/Core/CM3/core_cm3.c
...AppData\Local\Temp\ccmuucl9.s: Assembler messages:
...AppData\Local\Temp\ccmuucl9.s:492: Error: registers may not be the same -- `strexb r0,r0,[r1]'
...AppData\Local\Temp\ccmuucl9.s:516: Error: registers may not be the same -- `strexh r0,r0,[r1]'
mingw32-make[3]: *** [c:/OpenPilot/Openpilot/build/fw_coptercontrol/core_cm3.o] Error 1
mingw32-make[2]: *** [fw_coptercontrol_install] Error 2
mingw32-make[1]: *** [all_fw] Error 2
I also noticed the 2 QT download links in the wiki are not longer valid.
qt-sdk-win-opensource-2010.05.exe or Qt_SDK_Win_offline_v1_1_1_en.exe. Can they be upgraded with version version 1.1.4?
#10 PT_Dreamer
  • 1211 posts
Posted 30 January 2012 - 11:47 AM
Just to make sure we are using the same version this is my output of "cs-make -v"
GNU Make (Sourcery G++ Lite 2011.03-42) 3.81
About Qt, it works with 4.7.4 and 4.8. The new webinstaller from Qt allows you to install several versions including the beta.
#11 Berkely
Berkely
  • 615 posts
Posted 30 January 2012 - 05:30 PM
Yes, it's the same.
Copyright (C) 2006  Free Software Foundation, Inc.
I'll have another look over the complete process & try to figure out what works & what doesn't. I'll be traveling the following days so it's gonna take a while.
What bothers me a bit is that I followed the wiki description from scratch & it worked straight forward, then suddenly (without changing anything i believe) the process generated errors. Now a complete new installed OS together with the toolchain results in the same errors.
To be continued.
#12 Berkely
Berkely
  • 615 posts
Posted 03 February 2012 - 02:12 PM
Ok, I've got it building on my new OS. Wiki was correct apart from the download links.
It seems my problem was I've downloaded wrongly the SDL runtime libraries for win64 bit instead of the dev. libraries. I personally cannot link that to my error but that's what I found & it's building again now. :)
