JST-SH 4-pin connectors
10 replies to this topic
#1 ANV
ANV
  • 256 posts
Posted 15 January 2012 - 01:35 PM
I remember there was a link on wiki to ebay lot, where I can buy 4-pin JST-SH connectors, but now I can't find both - link and ebay lot.
Anyone knows where I can get them?
Digikey is not an option - delivery costs 10 times more than connectors itself.
#2 AlPackin
    Not the Llama
  • 2008 posts
Posted 15 January 2012 - 01:41 PM
I ordered these about 2 weeks ago but haven't received them yet
http://www.ebay.com/...1#ht_2347wt_905
#3 ANV
ANV
  • 256 posts
Posted 15 January 2012 - 01:49 PM
Let me know how they fit. The only reason I did'n order them is female connector looks a little bit different form what we see on CC. Pins are too short and mounting pins are at the side of pins, not at the side of male connector.
#4 AlPackin
    Not the Llama
  • 2008 posts
Posted 15 January 2012 - 02:07 PM
damn, I sure hope they fit :(
#5 comster
comster
    Team Gray Goose
  • 294 posts
Posted 15 January 2012 - 03:32 PM
I got those too, and they fit fine.  But they are so tiny, it is really tricky to solder the female socket.  I'll have some pictures later on my XBee thread.
#6 BrokenRotor
BrokenRotor
  • 180 posts
  • LocationMiddle Tennessee - USA
Posted 15 January 2012 - 03:41 PM
Those are 1.0mm pitch, so are the correct ones.   I got tired of trying to see through the various magnifiers and went all out for a Christmas stereo microscope!  Night and day difference, I can now see a .5mm pad like looking at my hand in front of my face. :)
#7 ANV
ANV
  • 256 posts
Posted 15 January 2012 - 04:16 PM
I've got myopia, something around -4 dioptries. That is too bad that I have to wear glasses, but I can solder and inspect .5mm pitch with no problem :)
Good news :)
Do they have connectors on both sides of the wire or not?
#8 c2po
c2po
  • 796 posts
  • LocationAtlanta, GA
Posted 15 January 2012 - 04:51 PM
Wiki also points to that item:
http://wiki.openpilo...penPilot+Cables
and I believe I've bought them from the same seller few months ago, they fit.
#9 comster
comster
    Team Gray Goose
  • 294 posts
Posted 15 January 2012 - 05:07 PM
The male JST-SH plug is connected to 4 long wires and is easy to deal with.  The female socket just has four long, thin metal contacts along the plastic (not sticking out).  Not sure how you are supposed to connect to it, but I did manage to solder four tiny wires to the contacts using a lot of masking tape.  That connection has no strength, however, so I gobbed it up with hot glue.  Would be great to learn if there is a proper way to do this.  It would be much easier to cut an extension cable, but I didn't get one.
#10 D-Lite
Posted 15 January 2012 - 10:30 PM
They are meant to be surface mounted to a PCB, not for directly soldering a cable to them. As you said, a direct solder connection is not very strong. A small breakout board would probably be the better choice.
#11 ANV
ANV
  • 256 posts
Posted 16 January 2012 - 04:15 PM
Thanks, looks like it was moved there from here http://wiki.openpilo...inalId=21365109 :)
That is the difference I was talking about. CC connectors have a small leads.
My PCBs got stuck for a Chineese New Year, so I got 2-3 more weeks to find exact connectors...
Thanks alot, will keep ebay as backup option :)
