The idea was mainly about using a smartphone as GPS/MAG and Camera, would be i think a very low-cost solution and could also record to SD and stuff like that. Telemetry and command interface using GPRS or fallback SMS is an addon. Limited in flight altitude, but nearly unlimited in range ;-)
I think a smartphone is not heavier than a camera, and replacing the battery i do not think will help much, because the additional energy you then pay for with a bigger main battery :-)
There are people that tested GSM and stuff in Europe and managed to get up to 500m above ground. Question is: how good is your camera ;-) And: in Europe maximum allowed altitude for model airplanes/copters is 150m... so this should work.
What can be implemented in the smartphone is a check of field quality and transit that back to the ground station, and additionally do not let the copter go higher if in low field strengths.
I will order some bluetooth module to be connected to the CC (any suggestions?) and then do a few tries.
Edited by XXL-Wing, 16 January 2012 - 01:51 PM.
No matter how good your backend systems are, the users will only remember your front end. Fail there and you will fail, period. -- Tristan Louis
Don't make me think. -- Steve Krug, usability expert
