Im very happy to hear you like the design guyz, means im on the right track here =)
Drifter, on 31 January 2012 - 04:51 AM, said:
Some very good ideas coming out here.
"Again its for the ppl idea" I was thinking you could call it the VolksCopter but that name has been used before.
http://theoldmotor.com/?p=13094
One thing that hampers a folding design is the propeller blades hanging out but I noticed that on the LotusRC T380 ARF Quadcopter, they don't use motor shaft retaining clips and the motor shaft ,bell,propeller assembly is easily removable , I wonder if there is enough magnetic force to hold this assembly in place and if so this would help to reduce the size of the folded copter although you would then need to find a place put these.
LotusRC.tiff
Hehe, thats a catchy name
I was thinking more of a Revo450 or Revo550 depending on a m2m distance, it will be determend when i research wich has the best efficiency ratio betwene electronics cost/flight time/and punch power to deliver appsolut vertical control giving the comfort in flying.
as for blades, well im all in favor of using prop savers enableing to take of propellers but that is not mandatory.
heres a quick drawing to show it has space for fixed propellers.
now the magnet part to lock motors in place. that might be of a safety issue wich i would rather avoid. better just bare with tiny comfort issue of propellers than leaveing any space for accidents, well in worst case ofc
Donald i would use several materials, there best properties.
For instance, molded case that has two piece design right, now that for it self is ok but considering the nature of the main body hull (I shape)there would be a lot of bending stress both on longer and smaller side,
to prevent this, i would use 2 small carbon I shaped profiles that get installed in predesigned slots in souch way it would reinforce the hull preventing bending in any axis, this also alows plastic body to has less tickness lower weight and appsoult streinght. carbon profiles is not just the material properties but a profile shape as well.
this is the solid way to build things, using more materials to achive required construction properties.
further more, i want to take Thurst efficiency lost area(arms bellow propeller thrust) and use the arms as 'ventilation channel" to reuse lost thrust into a active cooling ventilation system to cool down body electronics at little to no extra weight adding.
however it is something that needs empyric testing as i can only assume there could be issues with air turbolance inside body doing wierd oscilations/vibrations to the multirotor as construction.
in theory, more thurst you punch, more agressive you fly, more stress on escs, you get more thrust ventilated directly to escs. its a mutual system love hehe
i also feel a very simple add on to frame design would be of great feature,
small o ring right in CG of the body to make it easy to ballance entire quad for a end user, insted using 4 lines to each motor, simply hook up 1 line at that ring found on top center of quad and see is it lvled and you can instantly see is there some part of quad that weights more.
Edited by Dadorcp, 31 January 2012 - 12:07 PM.
