After building a Tricopter i kinda got hooked and now i'm building myself a new quad.
The idea started when i was looking and learning about multirotors and thought; that i could do better.
Not by design but as i learned as newb. that weight is key for most efficientcy.
So to be sort; enjoy.
Parts.
- Center Plate CF center-plate out of 1.5mm thick laminated sheet.
- Motor Mounts CF motor mounts out of 1mm thick laminated sheet.
- Arms HK-250 Tailboom.
- Tailboom Clamps HK-250 Tail-fin band.
- Motors Hacker 20-50S.
- ESC's Turnigy Plush 12amp.
- Elektronics Protection 100mm Christmas Ornament.
- RX FrSky 8channel telemetry.
- Battery Turnigy Nano 2200 3S1P.
- Flightcontroller OP Copter Control.
- Wires 20AWG thicknes.
- Props 8x4.5'' El Cheapo.
Weight calculation of this all.
10.8gram 100mm diameter CF 1mm thick frame
3.6gram 4 * motormounts CF
116gram 4 * motors 20-50S hacker
52gram 4 * 12amp turnigy plush
12.8gram 16 * tailboom-mounts with screws
18gram 4 * booms
15gram CC bord (estimated)
18gram 4 * 8'' GWS 2-blade Props
28.8gram 20awg 3.60meter
6gram hexagonal spacers with m3 bolths
5gram 4mm hxt accu plug
12.2gram 8ch FrSky RX
23gram dome
9gram battery strap
330.2 gram
187gram Turnigy nano 2200mah 3S1P
517,2 gram take-off weight.
Update; It actualy turned out that i wasn't that far beside.
AUW with 2200 bat. = 509gram.
________________________________________________________________________________________________________________
Also added the template's. Have a look maybe you like it.
I've made it simple, so everyone can make the pieces, out of CF or GFK or anything you like, by hand.
How To;
You can use and download google skechup for free. Open and download the .skb file and zoom in to the part you want to print.
Than set under camera tab, the carmera to ''parralel projection''. Then under camera click ''standard view'' and than ''top view''.
After this you need to figule a little bit around and do a ''print preview'' to see how manny pages sketchup does want to print,
because sketchup tends to also print the border space, so always first try preview print.
After you've printed the template simple glue it onto a piece of CF or GFK and you have youre guide lines where to cut beside.
.DWG file
.SKB file You need a extractor like winrar though.
For those who wan't a rib bone design landing gear can order it at shapeways. I've also added 5 and 10 pieces. (look under my account).
http://shpws.me/3PVh
Oké now some pictures.
To be continued.
Edited by jbkappirossi, 30 November 2012 - 12:06 AM.
Netherlands
Italy
Switzerland
Spain
