Pretty hooked as I've already built 3 different DIY quads in that time.
Here's another idea, perhaps build log over the next little while.
Seeing I have a perfectly functioning standard quad, the priority is concentrating on learning how to fly FPV, with a bit of tinkering in the background.
I know there's a guy called DEX who makes some really sexy looking fibreglass frames. Would love to buy one of those but believe that they're hard to get, not totally waterproof and perhaps a bit small to fit much FPV gear?
Anyway, here goes...
The capsule/case for my normal quad started off waterproof, a tupperware container.
It's easy to just waterproof part of the quad, can just seal the holes I made for ESC wires, the TX antenna and USB cable - with silicon sealant, and the CC board and RX would be in their own waterproof capsule. Will probably do that soon.
The other simple solution would be to run pool noodles down the arms of the quad, which would provide more buoyancy than the weight of whole unit, making it float if crashed into water.
In this scenario, all electrics would be lost, bar the CC board and RX. Possibly main FPV electrics could be preserved, if that stuff was in it's own tupperware container too.
But the challenge is to build an almost totally waterproof multi rotor.
Here's what I've done so far...
1. tested making a motor housing at the end of existing arms. 50mm PVC piping (from Bunnings) was used. This allows a little airspace around the motor, as heat might be an issue in an enclosure that's too small. Can always move to larger diameter piping, or most other motors have smaller bells than the DT750 used for reference.
This was waterproof, I left immersed overnight (pic below). Buoyancy was also added by the airspace in the 50mm housing.
The wires should be ok as long as sealed at each end and shielding is intact. Have made drop cams with dive buddies that we use in the ocean with housed security cameras at the end of 200m of Cat 5 cable, and haven't had a cable prob yet.
The photo might not show it properly, the housing is immersed and so are the shielded parts of protruding wires.
But... using PVC tubing allows it to look a bit neater and resist abrasion, with wires threaded through the middle.
Plus possibly adding a little buoyancy, due to the airspace inside.
2. Sealing. The next question was how to seal the motor housings. The bottom and arm slots are easy, can use epoxy or silicon. The motor will be hard to access once sealed, an idea is to probably make a complete spare arm, and swap it out if there's a problem.
Using silicon means a flexibe sealant, so it can be cut away, then resealed once any work is done to the motor.
I used a 50mm hole saw to make top and bottom caps (pictured below), drilling into the side of a plastic (Ikea-style) storage box.
So this round bit, sealed with silicon glue will be the bottom of the motor housing. Epoxy is something to think about as an alternative, then restricting access from only the top.
By chance, the hole saw makes a hole in the middle, which is great to poke the motor shaft through at the top.
The primary weakness of this design will be the prop shaft, as a millimetre or two needs to be allowed around it to spin. With the battery mounted low, it should float upright, so the main danger will be flipping the multi rotor in the water.
Going to try a number of different ways of sealing the prop shaft, using vaseline is one idea.
Another is trying a flexible boot (pic below) that they use in model boats. Not very confident that this will handle a fast rotating prop shaft. Perhaps this plus vaseline?
Suggestions would be greatly appreciated!
The arms could then be epoxied into holes drilled into the main body of the unit. Each motor housing will be sealed separately, so if there's a leak in one, it shouldn't reach the main body or other parts of the unit. A bit like chambers are individually sealed in boats, hopefully containing a potential problem to only one area.
3. Body - Tupperware again here.
The container needs to be oversized, not only to fit everything in but because of heat.
The ESC's and FPV electrics will all be housed in the main body, meaning that extra airspace will be needed to deal with heat.
I'm using Turnigy Plush 30A ESC's which don't seem to be too overworked, keeping head down in general.
If heat becomes a problem for the ESC's or other electrics, I have some small computer heatsinks from Goodluckbuy to deal with the issue.
Being clear helps you see if water has seeped in.
I picked this particular model of container for a few main reasons;
a. It has 4 clips, instead of 2 that the rectangular ones have (giving more impact resistance and security).
b. It's deep enough for multiple layers of electrics and a small frame to hold the arms.
c. And wide enough to (just) take the battery across its width. A 3000MaH battery fits flat.
d. the volume is 1.5 litres, giving approx 1.5 kg of buoyancy, more than the weight of its contents.
e. there seems to be enough spare airspace for cooling (I hope).
Once loaded up, it might be slightly too small, if a problem with space or heat, I might have to try and find the same thing in a 2 litre size.
So the CC board, RX, ESC's, battery and FPV gear will all be sealed in this enclosure.
Guessing that making it waterproof will result in about a 1.8kg AUW (say 2kg max), so thinking it will be a quad with large props, or maybe a hexa with 8 inch props.
Perhaps a hexa might provide the added advantage of a little redundancy? Not sure yet.
4. Buoyancy - The airspaces in housed areas should provide greater buoyancy than components, making it float.
Going to try and position weight (the battery) so that it naturally floats upright. As mentioned, flipping in the water will be the main danger.
Will probably add some flotation at the top of the body, so it wants to right itself, naturally.
An added precaution will be pool noodles along the arms, probably resulting in more than 5 kg's of floatation for a multi rotor that weighs about 1.8kg. Buffer if an area gets flooded.
A GoPro in its housing will be stuck to the outside of the main body. A FPV camera could also be made splash/water resistant on top.
That's about it for now. Everything needs to be thoroughly tested with the right weight but without electronics inside, which will take a while...
Edited by John888, 31 January 2012 - 06:47 AM.
Croatia
Austria
