New software release: 20120201-213a915f
150 replies to this topic
#1 peabody124
    Banned
  • 5870 posts
Posted 10 February 2012 - 04:18 PM
OSX: OpenPilot-20120213-35fb0b3c.dmg
Windows: OpenPilot-20120201-213a915f-install.exe
Linux 32-bit: openpilot_0.1.0-20120201-213a915f_i386.deb
Linux 64-bit: openpilot_0.1.0-20120201-213a915f_amd64.deb
Important notes:
  • This upgrade will erase all your settings and you will be required to reconfigure your aircraft. This should be the same as previously EXCEPT for the input configuration (see below)
  • The new input configuration has worked for a lot of people, but be aware it is quite sensitive. When it asks you to move a stick, just move it gently and be careful not to move the other stick. If you do then you can simply click back and try again.
  • This provides a unified firmware for all receiver input types.
From the changelog:
2011-12-10
Merged a change that sorts the UAVO fields based on size. Because this changes
all of the objects, erase all existing flash files based on this.
2011-11-04
New Spektrum/JR satellite receiver driver implementation.
It now provides explicit selection of DSM2 (and DSMJ), DSMX (10bit) and
DSMX (11bit) serial protocol variations to better serve different frame
and resolution modes. The protocol name used now is DSM instead of
previously used Spektrum to make it less ambiguous when used with JR
2.4GHz radios.
2011-10-20
Inputs can be remapped to outputs to allow up to 10 channels of control. The
receiver inputs remap as follows:
Receiver 3 because output channel 7
Receiver 4 because output channel 8
Receiver 5 because output channel 9
Receiver 6 because output channel 10
2011-10-11
Fix for the Mac telemetry rates and specifically how long enumeration took.
2011-10-08
Make the flash chip need to be have bad magic for a full second before erasing
settings. Should avoid random lost settings.
2011-09-12
Max rate now ONLY applies to attitude and axis lock mode. Manual rate is the
only term that limits the rate mode now (and in axis lock when you push stick
only manual rate applies). Also integrals are reset when unused.
2011-09-09
Some large updates to the input system. Now multiple receivers can be
connected at once. A wizard was added for configuring the input channels. A
specific collective pitch channel was added.
2011-09-04
Improvements to the failsafe handling code for inputs. PWM power off is now
detected properly. Powering on transmitter for Spektrum Satellite no longer
causes a glitch on servos.
Testing crumple zones
#2 Kenn Sebesta
    Banned
  • 2788 posts
Posted 10 February 2012 - 05:02 PM
Great news! Just to point out for everyone, this is a pretty major upgrade in functionality since the last public release. The ability to use Spektrum, cameras, extra outputs, etc... is really wonderful. Hats off to our marvelous devs who have done so much.
#3 TomSn0w
TomSn0w
    Advanced Nerd
  • 115 posts
  • LocationUnterfranken
Posted 10 February 2012 - 05:13 PM
Gotta try that!
#4 Fredator
Fredator
  • 483 posts
Posted 10 February 2012 - 05:35 PM
Ace!!! Thanks for the hard work, guys!
Currently flying: Turnigy H.A.L. Quadcopter, OpenPilot Revolution, 4S setup with 9x4.5 props
#5 David J
David J
    Flying in ever decreasing circles...
  • 1591 posts
  • LocationBentley, Suffolk
Posted 10 February 2012 - 07:30 PM
Is the matching Linux build coming along soon? (he says, hopefully! :) )
This page intentionally left justified...
#6 ANV
ANV
  • 478 posts
Posted 10 February 2012 - 08:40 PM
Awesome! You make me forget it is -15C/5F outside :)
#7 glikar
glikar
  • 103 posts
Posted 10 February 2012 - 08:55 PM
Looks great! Nice features. To do linux build I ass_ume its in master, not next?
#8 Kenn Sebesta
    Banned
  • 2788 posts
Posted 10 February 2012 - 08:58 PM
...master, not next?
Right, any public release is going to be master. Next is for all intents and purposes just as stable (I've never run into a single flight-critical bug), but once it stews and simmers for a long time it goes to master and then there can be a new public release.
#9 juz
juz
    誠実
  • 4369 posts
Posted 10 February 2012 - 10:07 PM
Thanks James. (Prolly a stupid question) Which flight test team build is this?
#10 barrelheaven
barrelheaven
  • 58 posts
  • LocationCalifornia
Posted 10 February 2012 - 10:34 PM
Woo sounds awesome. Just downloaded it. How would I go about saving the settings from my old?
#11 AlPackin
  • 3513 posts
Posted 10 February 2012 - 10:49 PM
File>>Export UAV Settings
#12 peabody124
    Banned
  • 5870 posts
Posted 10 February 2012 - 10:50 PM
Be warned importing settings often crashes on OSX.
#13 AlPackin
  • 3513 posts
Posted 10 February 2012 - 10:52 PM
yeah, its a lot different, just write down your settings and enter them again after the upgrade
#14 naiiawah
naiiawah
  • 309 posts
  • LocationNorthwest USA
Posted 10 February 2012 - 10:53 PM
Builds are churning, but I won't be able to test and then post them till I get back home tonight.
See the Wiki Page for the new section on the site for downloading Linux packages. But for the impatient....
here they are:
Edited by naiiawah, 11 February 2012 - 04:13 AM.
#15 BayAreaCrasher
BayAreaCrasher
    Meh
  • 3491 posts
  • LocationBay Area, CA
Posted 11 February 2012 - 01:13 AM
congrats dev team for releasing this. big usability improvement in the setup process.
#16 vantasstic
vantasstic
  • 42 posts
Posted 11 February 2012 - 04:04 AM
Cool. Thanks guys for the updates. A question...does this release include a/the new method for calibrating level for attitude mode?
#17 David J
David J
  • 1591 posts
Posted 11 February 2012 - 10:47 AM
here they are:
Impatient? Moi?
I can confirm that the 386 Linux build installs nicely, and accepts firmware loaded from the Vista version.
Well done everyone!
#18 AlPackin
  • 3513 posts
Posted 11 February 2012 - 11:44 AM
yes, here is a thread describing it and a screenshot of the setting screen showing the TrimFlight selection
http://forums.openpi...__flight%20trim
  • Attached File  ft.PNG   17.85K   165 downloads
#19 DanZ
DanZ
  • 341 posts
  • LocationDurban
Posted 11 February 2012 - 02:32 PM
Hey all
Thanks for the update. I just finished installing the new software and flashed the new firmware to my board via USB. However I have been trying to connect my bluetooth module and it is not working with the new software? I have changed the main port to telemetry and changed the baud rate to 57600, when I select the com port the BT is connected to and press connect it will connect and show a solid red light on the BT module but there is no actual telemtry link to the CC board?
I imagine its only a case of me forgetting someting small as it has been a while since I set up bluetooth, any one know what it could be?
#20 peabody124
    Banned
  • 5870 posts
Posted 11 February 2012 - 04:39 PM
@AlPackin: that thread is in the flight test build so not everyone can see. Could someone write that up again? (I would but hands hurting from too much coding this week)
