Anybody know if is possible made a cablecam like this using cc
cc on a cablecam
Posted 10 February 2012 - 04:31 PM
Posted 10 February 2012 - 08:34 PM
Why not? But what do you need to stabilize with CC? Since camera hanging on wire, in this particular setup you only need to control pan and tilt for camera.First of all sorry by my english
To avoid entire gimbal swinging on a wire there is mechanical gyro, so from a first sight it looks like you are fine with RX directly to servos.
Posted 10 February 2012 - 09:41 PM
Posted 10 February 2012 - 09:56 PM
Posted 11 February 2012 - 06:43 PM
I've seen the page that you put, and the prices are very expensive, too for me
Sorry to insist, but I am very new to this and I have little idea.
With a tx could move left and right, and then use other channels to the pan and tilt, right?
If anyone can help me in make a list of the materials that I need, i would be very greatful,
Right now I have one that works by gravity, but I want to make one to use it in any place
Sorry by ma english
Deshacer cambios
Posted 11 February 2012 - 10:14 PM
I don't know much about this system too, but looking at the pictures and googling for a bit you can get all the info you need.Thanks for the info. I thought to use a cc is too for this system
I've seen the page that you put, and the prices are very expensive, too for me.
Sorry by ma english
Deshacer cambios
The first thing you got to do is find out how much money you can afford to spend on the project.
Here is some info found on vimeo
View on Vimeo :
It is a hacker (a30-10L), but only because it was a motor I had on hand until my 850kV motor comes in. It's 1185kV (so FAR from optimal), and is pretty jumpy in the lower throttle ranges. But, it did work while we tested and got everything running.
You'll need ESC with reverse function to run gimbal in both ways.
If don't have access to CNC, some parts can be found here, lots of hardware: http://servocity.com...ccessories.html
Edited by ANV, 11 February 2012 - 10:15 PM.
Spain
Russian Federation
Austria
