GPS settings for telemetry
Posted 18 February 2012 - 02:25 PM
I have a Ublox 6 based GPS module and it is working fine, as long as I connect it to my PC through a USB2TTL adaptor. I tried it with the u-center software, GPS Utility and in GCS as GPS Mouse and Flight GPS connected through serial.
But as soon as I connect it to the CC Board Flexiport, it does not get a fix (constant green LED) and it is shown red in the GCS System Health gadget. I activated the GPS module under "HWSettings>optional Modules" in the UAVObjects Browser. Both CC and the GPS are set to 57600baud.
Did I miss a setting or do I have to select only certain NMEA messages? Does it only show up green in System Health, if it gets a fix?
Sebastian
Posted 18 February 2012 - 03:29 PM
I've struggled with this as well. I've tried several different GPS units, and getting a lock is a real challenge. I spent quite a lot of time testing this, but eventually had to move on to something else without coming to any real conclusions.
There certainly seems to be something about connecting to the CC that makes a lock difficult. I ran two identical GPS units on the table next to each other, one connected to the computer, and the other to the CC. The computer GPS locked, and the CC didn't. I switched the connections around several times to verify that it wasn't the actual GPS, but rather the connection that was at issue. At some point, I'll have to do more testing, and maybe put a scope on the wires from the CC to see if I can see any reason for it.
I can get a lock on an old EB-85A, but it appears to be weak. On the health gadget, red is actually good. It seems to indicate that the GPS is communicating, but doesn't have a lock. It will turn yellow when you get a lock, and eventually turn green at 7 sats. What you don't want is white with a red X through it, since that means it's enabled but not communicating.
As for NMEA messages, I have no idea what is needed. I've tried various settings, but that's not the lock issue of course. It would be nice to know what messages are needed, so the others could be turned off.
I do know that David has spent plenty of time with GPS units, and apparently doesn't have issues with locking. I'm not sure what the difference is though.
Cheers,
Rusty
Posted 18 February 2012 - 04:36 PM
Sebastian
Posted 18 February 2012 - 04:58 PM
Posted 18 February 2012 - 05:56 PM
Posted 18 February 2012 - 06:32 PM
Posted 22 February 2012 - 04:41 PM
Sebastian
Posted 28 February 2012 - 01:50 AM
Did you followed the Wiki instructions using the Bluetooth module or have you conected these modules directly to the comunication ports (PC and CC board) ?
thanks
Posted 28 February 2012 - 06:17 AM
So I can verify that they're pretty sensitive to interference. Fastrax makes a model with an extra SAW filter, which they claim is good for telemetry applications where the GPS is near a transmitter.
Posted 28 February 2012 - 01:58 PM
thanks
First I connected both APC220 modules to my PC using the provided USB2TTL adaptor and configured them according to the wiki. Then I left one connected to my PC and connected the other one to the CC boards MainPort. I made the connection cable from the JST-SH4 cable that comes with the CC, cut off one connector and crimped servo terminals to that end. The software to configure them was kind of hard to find, it seems RF-Magic is discontinued. I post a zip with the software I found.
The connection itself is like any connection through a serial port. GCS does not care or does not know, if it is a cable, bluetooth, or a serial RF link.
Right now, my copter is on my balkony and I am 20m and several walls away from it, watching the GPS data, so the APC220 works just fine.
One thing you should know, you can configure the APC220 to different frequencies, be careful to pick one that is legal in your country. (433MHz is alright in Germany and maybe for Portugal)
Good luck,
Sebastian
Posted 28 February 2012 - 02:03 PM
All I did was disabling the u-blox NMEA extensions and now it works just fine. I have a fix with 6 SVs near to a wall and with a balkony above it. Will test it on an open field in the future.
Posted 28 February 2012 - 04:08 PM
I think it's still putting some noise out in the 1G range, where I can't see it with my scope. Hopefully I can eventually figure out a proper filter for the setup.
Right now if I power it from the TTL adapter it gets only a few signals inside. If I power it from my dev board it's a little better. And it's pretty decent if I use a battery. This is all without a transmitter involved, so I've probably got some work to do.
-Jake
Posted 28 February 2012 - 05:06 PM
Good luck,
Sebastian
Thanks for the help, one more thing... are you using these rf modules @ (1, N, 8, 9600) or did you managed to get more speed, these are suposed to work at that maximum, but perhaps a little more can be achieved ?
edited: the Rfmagic doesn´t detect my APC modules, i´m using win7 - 64bits, no comm port is detected with the USB and module connected !!!
thanks
Edited by miniplanes, 28 February 2012 - 06:08 PM.
Posted 28 February 2012 - 07:14 PM
If you see no new comm port, change your USB connection. My USB2TTL adaptor is not detected or marked with exclamation mark in Device Manager, If connected to an USB-Hub or front USB port. Connection with an USB extension to a rear USB port works just fine.
You have to start RF-Magic as administrator, otherwise you get an error message.
Posted 29 February 2012 - 01:12 PM
thanks for the tips
Edited by miniplanes, 29 February 2012 - 01:12 PM.
