Quad Settings.xml 109.96K
6 downloads
First Flight Help
Posted 20 February 2012 - 02:24 PM
6 downloads
Posted 20 February 2012 - 04:28 PM
I cured this (mostly) by practicing in a simulator.
Posted 21 February 2012 - 11:33 AM
Assuming David is correct and you are new, like I am, then yes, it's all pilot error LOL.
The sticks are HIGHLY sensitive, well, tons more than I was expecting anyway. Which I guess is good thing to learn on. It keeps your focus, demands full attention.
So yes, it is very easy to pogo until you get the hang of just how sensitive the sticks are. Well, the throttle specifically. You gotta think about it this way, you've got enough power to lift a lawnmower there so take it easy!
As much as I want to gun it full throttle on takeoff I'm still quite skerred to do so, but am working my way up slowly ;-)
Good luck keep us posted
Edited by astronutski, 21 February 2012 - 11:42 AM.
Posted 21 February 2012 - 12:36 PM
I use a BIG car-wash sponge, cut in half now, strapped to the bottom of my frame, and black pipe insulation on my arms under the motors,
takes alot of the impact out of the landings, except if its wet out,
tends to soak up the water and gets heavy,,lol
or you could use, rolls of toilet paper,,,,did that,,too,,
Posted 21 February 2012 - 01:00 PM
Also, as others noted, small, precise and continuous control movements are pretty crucial for heli flying. Maybe not so much on well stabilized platforms, but finesse still helps.
Rick
Posted 21 February 2012 - 01:57 PM
Posted 21 February 2012 - 02:48 PM
GeeBee, on 21 February 2012 - 01:57 PM, said:
Did you readjust the throttle curve in GCS like they suggest? That should make it a little less twitchy around mid throttle where your hover should be. I don't yet know how to read those XML files, so if you attached some screen shots of your configurations in GCS, it might help. BTW- I'm a beginner too, but I've managed to tune mine in so it's pretty flyable. Still a lot to learn though. I think that tuning the PIDs probably involves a little voodoo
Rick
Posted 21 February 2012 - 07:04 PM
Now my quad has Frankenquad 'Rib Bones', which are near indestructable...
http://www.hauntnet....b5db05d05ce218a
Posted 22 February 2012 - 02:19 PM
Posted 22 February 2012 - 05:18 PM
Don't feel bad, I got into this hobby last year and a still have a lot to learn. This forum is great, people have help me a lot.
I would suggest get a flight Simulator, I use Phoenix. I did crash a lot in the beginning, bot now I hold my own. Also, I built a mini which I use indoor to practice. I have not broken a prop in months now.
Talking about props, I would recommend buy a bunch (tip from this forum). I had my share of broken props. Also, make sure they properly balanced.
For tuning, I read a lot of comments from the forum and the wiki site and ask a lot questions. This has help me immensely.
Before buying parts, I would ask the forum. I made my share of mistakes.
Always think of safety of others and your self.
Hang in there, this hobby is addictive. It may not make you younger, but its fun.
Posted 22 February 2012 - 05:30 PM
In the GCS goto Files>>Export UAV Settings
name the file whatever, it will save it with a .uav extension (not xml)
the .uav can then be imported back into the GCS if you want others to view it or you have to restore your CC setup
Posted 22 February 2012 - 06:47 PM
I was having the same problems you are experiencing with throttle control. And I thought it was due to my throttle curve settings.
But as everyone has said, it's more a case of throttle practise and getting the feel of it.
AlPackin-Mat, Seismic and others on the forum are a great help to us newbies.
I'am using a vic 450 frame so I attached large chunks of pool noodle to all four legs as shock absorbers for my heavy landings.
Then I had the idea of fixing squash balls to the landing legs after my landings improved. Great bounce factor.
I found a good method is to load up the frame, add some weight, this slows up the throttle stick response and makes it a bit easier to control while you are learning.
I also found that using a 2s lipo for practising landings and takeoffs decreased the power and made the throttle response a lot less touchy.
As a newbie, I have a long way to go, but watching some of the vids from members on here is inspirational.
So I will keep practising.
Cheers.
Posted 22 February 2012 - 07:10 PM
It's just a case of practice, practice and a bit more practice. If the UK weather ever improves then I can get out of the back garden in the brief dry spells and into a proper-sized flying field, and maybe I can get some more real practice in as well! A simulator is good, but you can't beat the real thing...
Posted 23 February 2012 - 04:53 PM
GeeBee Quad.uav 8.94K
2 downloads AlPackin, Thanks! That's what I needed and David J, I'm leaning towards what you've done, a straight line. I think I would understand what's going on better with that setting.
Posted 24 February 2012 - 01:57 PM
Spain
