CC won't level.
Posted 21 February 2012 - 08:10 AM
Posted 21 February 2012 - 09:13 AM
glikar, on 21 February 2012 - 08:10 AM, said:
I should have added that it flew great the day before, hovered rock solid level all the way up to the tree tops. Unfortunately at that point I panicked and brought it down a little fast. On the upside my quad landed on a mogul pine shrub, luckly its foliage is soft like a pillow, at least for a quad landing.
Edited by glikar, 21 February 2012 - 09:14 AM.
Posted 21 February 2012 - 09:34 AM
They should all be < +- 1
If they are beyond this, please try locating the gyro chip (small black chips on the left hand side of the board with the USB down) and pressing on them
Posted 21 February 2012 - 09:56 AM
Posted 21 February 2012 - 10:21 AM
Temperature can cause this issue, taking the board from warm inside, to cold outside will affect the gyros... let the board stabilize in temperature before arming and flying....be cautious on condensation as well...no rapid temp changes. Also be sure to wait 10 seconds after arming before you touch your throttle
Posted 21 February 2012 - 12:26 PM
Posted 21 February 2012 - 03:01 PM
Edited by glikar, 21 February 2012 - 03:01 PM.
Posted 21 February 2012 - 05:08 PM
My scope range is +- 0.3 . Pressing on the gyro produced different results, the graphs zeroed, then spiked and settled down.
Tried my backup board it worked fine.
I'm guessing the hard landing broke a solder joint. The gyro are rated to 100k g's so it's unlikely the're damaged. Don't think the quad did a free fall, but if it did the impact would only be around one g. It was roughly 10 meters high. Are my assumptions reasonable?
Posted 21 February 2012 - 05:16 PM
Posted 21 February 2012 - 05:30 PM
K Wells, on 21 February 2012 - 05:16 PM, said:
Out of curiosity- how should one of these boards be reflowed? I've reflowed HP printer formatter boards in a 350 oven for 8 minutes with good results. Would this work with a CC board?
Rick
Posted 21 February 2012 - 05:42 PM
K Wells that's a good question. Haven't tried anything that small. I have a microscope and replaced one eye piece with a Bevrc mini cam, which feeds a pair of MyVu glasses, also have an inexpensive hot air rework station. Not sure I'm ready to reflow the complete board. Any tips on how to rework it would be appreciated.
Posted 21 February 2012 - 05:54 PM
Posted 21 February 2012 - 06:41 PM
Back to the damage question. I'm perplexed, because nothing else was damaged not the frame nor landing gear. CopterControl is in a case, it and camera sit on a sprung platform.
IMG_0982.JPG 573.78K
9 downloads
Posted 21 February 2012 - 07:17 PM
Posted 21 February 2012 - 07:51 PM
Posted 22 February 2012 - 07:15 AM
tvtime-output-09:36:25 PM.png 1.19MB
17 downloads
tvtime-output-09:36:51 PM.png 1.19MB
19 downloads
tvtime-output-09:40:15 PM.png 1.19MB
20 downloads
tvtime-output-09:42:33 PM.png 1.19MB
15 downloads
Posted 22 February 2012 - 01:41 PM
glikar, on 22 February 2012 - 07:15 AM, said:
It does look like they probably need to be resoldered. It's somewhat deceiving to look at, but there are actually no pins on those chips. The chip has a pad that wraps around from the bottom to the side, but no leg of any kind. The solder is just on a pad on the board, and when it's all heated up properly, it should flow to the pads on the chips.
Cheers,
Rusty
Posted 22 February 2012 - 09:22 PM
