Another CC board makes it into the air
11 replies to this topic
#1 2400rdr
2400rdr
    Embryonic Multirotor Geek
  • 133 posts
  • LocationTallahassee, FL
Posted 22 February 2012 - 02:19 AM
Test flew my woody quad tonight. Nothing fancy because it was after dark and the thing doesn't have lights (yet). Tested hover stability, directional response and throttle response. All really good with just the default settings. CC rocks!
CC board
AR6255
DT700 motors
Plush 18A ESC
10x4.5 props
a few sticks and a little plywood
The surprise was how powerful the DT700 motors are- a lot of headspace available.
I've included some photos. Obviously I need to finalize the build: shorten the motor shafts, tidy up the wiring, add protection for the electronics, balance props and attend to a few other minor details. Love it.
Rick
#2 K Wells
  • 2229 posts
Posted 22 February 2012 - 02:52 AM
Have to love home built quads...looking forward to the Maiden B)
#3 dankers
  • 5129 posts
Posted 22 February 2012 - 02:55 AM
Nice work Rick, have a CC MultiPilot award :)
#4 Dream-fly
Dream-fly
  • 154 posts
  • Country: flag of India India
Posted 22 February 2012 - 03:34 AM
Rick,
What's the total weight of your Quad?
Also what's the Motor -to- Motor distance
and finally what is the Lipo battery you have on board?
#5 Adverse Effects
Adverse Effects
    Team Dropbear
Posted 22 February 2012 - 03:43 AM
have you got all of thos becs connected to the CC?
disconect all but one of them
use a pin to remove all the red wires but 1
by the way well done
How do you get a sweet little 80-year-old lady to say the "F" word?
Get another sweet little 80-year-old lady to yell, "BINGO"!
#6 LeeS
LeeS
  • 336 posts
  • LocationLake City, Florida
Posted 22 February 2012 - 05:30 AM
Why aren't you on the member map man?  I'm always looking to see if an CC pilots show up near me. :)
#7 2400rdr
2400rdr
  • 133 posts
Posted 22 February 2012 - 10:18 AM
View PostDream-fly, on 22 February 2012 - 03:34 AM, said:
Rick,
Even though this quad is about as simple as it gets, it has taken me a while to get it together. Last night I finally got it to the point where it had the minimum needed to test, so I did a quick config on the CC and went out and flew in the front yard. There's still some things to do to get it to the point of putting it in the air in a mode I consider safe- altering the BEC wiring is one of those things. I almost did that last night, but I decided to jump on it and go fly. Also, I need to cut all of the bolts to length and install washers and nylon insert lock nuts. In the photo of the undercarriage, you can see where I've already lost a nut :) That probably came off on the bench rather than during the brief flight I made last night,
I also plan to eliminate the bullet connectors between the harness and ESCs because they are where I can't see them, and I don't trust them all that well. The ESC to motor connectors are out there where I can see them, so I'm not too worried about those.
The AUW is somewhere north of 26 oz- it maxxed out my kitchen scale LOL. Guess I need a better one. 24" between opposite motors, and the battery is an old Zippy-K 2300mah 20C. I bought several of these back when I was flying CCPM helis. The K stands for Korea, and at the time, the Zippy-K batteries were better than the Taiwan Zippys. Supposedly. These are fine for now, but I'll probably go to some batteries with higher discharge ratings eventually.
Rick
#8 2400rdr
2400rdr
  • 133 posts
Posted 22 February 2012 - 10:25 AM
Lee-
OK- I added my humble novice self to the map :) There are two other guys over here that I know of with CC- I'll have to get them to join up too.
Rick
#9 2400rdr
2400rdr
  • 133 posts
Posted 22 February 2012 - 10:32 AM
Thank you sir! I'd crack open a Vic Bitters to celebrate if only I could find one somewhere in the States.
Rick
#10 John888
John888
    Learning by doing :-)
  • 174 posts
  • LocationBalmain
Posted 22 February 2012 - 01:25 PM
Well done Rick!
How thick is your ply? I've been playing around with a 3mm sheet of ply and found I had to (gorilla) glue two pieces together for each of the top and bottom plates.
Agree re. the DT motors, they're work horses.
Homebuilt Y6 Hexacopter (750kv motors, 11" and 12" props) - lifting a DLSR
Homebuilt FPV Quadcopter (1200 kv motors, 9" props) - lifting 1-2 GoPros
Homebuilt Tricopter (750kv motors, 11" props) - lifting 1-2 GoPros
Hombuilt Endurance Tricopter - 40+ min hover time (360kv motors, 15" props)
Bixler Plane (FPV enabled)
1900mm Skywalker Plane (on its way - to be FPV enabled)
Experimenting with ER9x, FrySky & a 1 watt booster
Experimenting with DIY 5.8ghz Cloverleaf, Skew Planar Wheel & Helicals
#11 2400rdr
2400rdr
  • 133 posts
Posted 22 February 2012 - 01:32 PM
View PostJohn888, on 22 February 2012 - 01:25 PM, said:
Well done Rick!
Well, in Imperial terms, the birch ply is 1/8" which I think is about 3mm. My plates are stiff though because of the way the arms are tied in. The arms end just short of the corners of the CC board. Nothing is glued together because I wanted the arms to be easy to replace in the event of an, ahem, mishap. It's all just bolted together. But, I only had it in the air for a minute last night just to see if it worked. When I get a chance to fly it around, the plates may reveal themselves as too flimsy.
Rick
#12 2400rdr
2400rdr
  • 133 posts
Posted 24 February 2012 - 11:34 PM
Flying sandwich box is complete. Probably add some LEDs for orientation some time. :)
