Variable Pitch Quad Copter Using single Motor
VPP Quad
168 replies to this topic
#41 azrin_aris
azrin_aris
  • 82 posts
  • Country: flag of Malaysia Malaysia
Posted 26 February 2012 - 04:01 AM
Congrats on doing this, it looks amazing!
I've seen a similar design but cannot find the link right now. They used belt driven tail assemblies and a dual motor setup on a sort of planetary gearing in the middle. Could have one motor fail and still fly.
Dumb question I guess, does the OP code have support for inverted flight on VP airframes?
Yes I did came across a couple of sites before and both are using 2 motors. That's motivates me to make the single motor system.
#42 BigpatAus
BigpatAus
  • 183 posts
  • LocationGlen Innes, NSW
Posted 26 February 2012 - 07:13 AM
Your link is broken..
I attempted a fix..it failed....you may want to re-link
Thanks for that I just updated the link. Hope it works now
P
http://diydrones.com...-implementation
Edited by BigpatAus, 26 February 2012 - 07:14 AM.
#43 Drifter
Drifter
    Drone Driver
  • Flight Test Team
  • 1581 posts
  • LocationSawtell
Posted 26 February 2012 - 07:37 AM
Might be the ground effect is causing the instability, try between 1 and 2 meters altitude.
VK2CH
Team Big Banana
Free Plans for Folding Quad
Building the Drifter-T
And God said Let there be FPV and there was FPV and it was good.
#44 azrin_aris
azrin_aris
  • 82 posts
Posted 26 February 2012 - 07:59 AM
You are right, test flight #2 this morning shows much better stability. However I guess I've set the head speed too low hence the sluggishness of the response.
#45 Mat Wellington
Mat Wellington
    Mix Master Mat
  • 1564 posts
  • LocationTaranaki
Posted 26 February 2012 - 09:52 AM
first off - well done ! great machine man, very cool
second, looks like it needs a bit more inner Kp to tighten it up
Third, - i cant see any reason why you couldnt go inverted, i assume you set up a curve on the throttle channel to control the motor the same as a heli, (full throttle at about 25%, drop it down to maybe 85% at mid and 3/4 position and back up to max at full stick ) and set up a linear pitch curve, and feed that to the CC as a throttle input, then on the CC do a throttle curve of 0=0, 25=0, 50=33, 75=66 and 100=100
that way the 4 servos will travel from full negative pitch to full positive pitch as you go from 25% to 100% throttle position, and from 0 to 25% is just to spool the motor up (controlled direct from the throttle curve on the TX )
very cool project anyways, cant wait to see it developed
#46 Gentle Lady
Gentle Lady
  • 24 posts
  • LocationMoyock, NC 27958
Posted 26 February 2012 - 11:42 AM
Don't know if you have seen this. Pretty amazing stuff.
#47 azrin_aris
azrin_aris
  • 82 posts
Posted 26 February 2012 - 11:58 AM
Test Flight #2 Video uploaded
#48 azrin_aris
azrin_aris
  • 82 posts
Posted 26 February 2012 - 12:00 PM
Thank you so much for the guidance. I'm studying the settings tonight.
#49 Adverse Effects
Adverse Effects
    Team Dropbear - QLD
  • Flight Test Team
  • 3082 posts
Posted 26 February 2012 - 12:21 PM
dam it was flying really well
i was worried about the gears :( i just didnt think they would strip from use, i thought it would take a crash
the only i can see around it is bigger and heaver gears
25/2/2013
Quad - 01 Build Blog (Now Dead)
THE BEAST My RC Lawn Mower Blog
My Eurgle 2.4Ghz 9ch (Turnigy 9x clone)
HEX-01 - Build Log
FPVRaptor Composite 1600mm - Build Log
if i link to hobbyking i use Affiliate links that pay me a few cents each time you use them
#50 Guest_dankers_*
Guest_dankers_*
  • Guests
Posted 26 February 2012 - 12:25 PM
That was flying so well, I agree with your comment at the end of the video, perhaps clearance is a bit too large?
#51 Adverse Effects
Adverse Effects
    Team Dropbear - QLD
  • Flight Test Team
  • 3082 posts
Posted 26 February 2012 - 12:27 PM
you do have to remember the gears are made to turn like 50mm blades not 200mm+ blades
Edited by Adverse Effects, 26 February 2012 - 12:27 PM.
25/2/2013
HEX-01 - Build Log
#52 azrin_aris
azrin_aris
  • 82 posts
Posted 26 February 2012 - 01:01 PM
Another possible cause is the material of the gear itself. It is not the original Align Trex Pro but from HK450 Pro. I'm buying align parts next to test it out.
#53 azrin_aris
azrin_aris
  • 82 posts
Posted 26 February 2012 - 01:06 PM
You got me thinking there to use Trex 600 tail unit. But how to shorten the torque tube - I have no idea at the moment. Or I just have to keep up sizing the frame, and the same problem will occur again 😜
#54 Adverse Effects
Adverse Effects
    Team Dropbear - QLD
  • Flight Test Team
  • 3082 posts
Posted 26 February 2012 - 01:19 PM
hehe this is why i am making the motors directly connected to the props ;-) nothing to strip out
25/2/2013
HEX-01 - Build Log
#55 Adverse Effects
Adverse Effects
    Team Dropbear - QLD
  • Flight Test Team
  • 3082 posts
Posted 26 February 2012 - 01:29 PM
just thinking about the problem
if you got a 2nd gear (the big one) and turned it upside down and had a spring pushing it down
Attached File  1 motor center drive.jpg   20.28KB   37 downloads
no drive going to it
its just there to push the drives down in to the main drive gear
Edited by Adverse Effects, 26 February 2012 - 01:30 PM.
25/2/2013
HEX-01 - Build Log
#56 K Wells
  • 3274 posts
Posted 26 February 2012 - 01:51 PM
I would suggest metal drive gears with proper pitch diameter spacing...I've simply used paper between gear mesh to achieve this...
Here are custom metal gear suppliers I use...many are stock!
http://www.rushgears...CFQReTAoduhgaMg
http://www.wmberg.co...ucts/Gears.aspx
#57 v22chap
v22chap
  • 1 posts
  • LocationGoshen , Indiana
Posted 26 February 2012 - 04:34 PM
Congrats on a job well done . Look forward to seeing more research on this one motor idea as I have been thinking the same thing , but have run into a problem of time as we moved and both houses need a lot of work ,,, one to sell it and the other to meet what the wife wants :) .
I was using the gearing to a Gaui 500 and going to use belt drive to props .. But would probably have the same problem with belts slipping pulling such large rotors as the 200 mm ones .
I love the idea of not having 4 motors that one motor or esc can go bad ... and if the single motor idea worked , I was going to try and put another motor on the drive unit ,,, just idleing as a back up motor .
Best of luck and please keep going with your great bird . Maybe bigger pitch gears or steel will fix the problem ... but maybe you may need to think about using gear reduction at the drive end of the tubes as to relieve some of the gear presure .
#58 LeeS
LeeS
  • 343 posts
  • LocationLake City, Florida
Posted 26 February 2012 - 05:54 PM
Are the belt driven tail units less efficient than the gear driven ones?
Seems like with belt driven you could have it with no angular conversions on the force and an overall lower part count. Plus you get the benefit of not having bent drive shafts in the event of a crash.
#59 azrin_aris
azrin_aris
  • 82 posts
Posted 26 February 2012 - 11:15 PM
This might work but currently I'm using HK450 pro tail mount and there is not enough space for another
#60 azrin_aris
azrin_aris
  • 82 posts
Posted 26 February 2012 - 11:18 PM
Thanks K Well, I've look at the website and I simply got lost. There are too many types of gears. 😊
Also tagged with one or more of these keywords: VPP, Quad
